hey daniel you still work for dominos :cool:
you got a few good ones of my 180 cheers man.
do u mean me??? i havent worked there for over 2 1/2 years, how did u no i did any way,
i didnt realise it was ur 180, which is rather nice btw, a fresh coat of paint and it would be very shmick
https://www.sau.com.au/forums/topic/314014-ahg-28310-pics/#findComment-5156019
yeah i use to work for dominos about 3 years back saw ya at a few rallys and pizza collage haha. i use to have a 32 with the white body kit now its all painted and rb26 converted. yeah my 180 is my drift cop so not planing of a fresh coat of paint for a while
https://www.sau.com.au/forums/topic/314014-ahg-28310-pics/#findComment-5156090
Looks like a fun day. Too bad Trevor couldn't correct his skyline properly and ran over a cone. Must have too much power for you to handle =P haha.
yeah well u should have brought your YEAH-RIS bro. Stop sitting on your ass and get the turbo in already :cool:
https://www.sau.com.au/forums/topic/314014-ahg-28310-pics/#findComment-5156380
    • So I actually had the cover off my car today, here is a (bad) pic of the setup. I have an oil cooler thermostat block, the temp sender is straight in there. The pressure sender has a short AN line to a T piece which is mounted (hopefully cable tied counts as mounted....) on the chassis. BTW every fitting you could ever imagine exists....just depends what they cost and how many you need. Raceworx AN adapters are here: https://raceworks.com.au/fittings/adapters/, I think you said you need BSPT to AN (https://raceworks.com.au/fittings/adapters/bsp/tapered/an-to-bspt-adapters/) and AN to NPT (https://raceworks.com.au/fittings/adapters/npt/) BTW, braided line is super simple to make. It looks intimidating, is not.
    • Perfect day for a pie, really needs a soft top in this weather though
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
