im lookin and gettin a different diff i have a r32 skyline it has the stock lsd but is still cutting one wheel even now and then what diff would be best for a street car i want somethink that is almost locked but has a bit of play for turning sharp eg parking and somethink that isnt heeps loud if possaible
https://www.sau.com.au/forums/topic/314404-what-diff-is-best/
A good cheap way to have a tighter diff is retain the stock LSD, but 'shim' it up. By adding extra preload shims (which are around $10 each), the diff will be a lot tighter.
From factory you are supposed to have two 0.80mm shims inside the diff centre. So that's a total of 1.60mm of preload.
You can use this guide here to show exactly how to shim your diff.
http://www.skylinesaustralia.com/forums/Di...l=shimming+diff
There's a lot of discussion on what shims should be used, I ended up buying the shims from my local Nissan dealer. I ended up having 2.45mm of preload. It skipped the inside wheel pretty bad for about a week and then it loosened up just a tad. Still feels very firm is very predictable when driving or drifting.
Just have a read of that tutorial link and it may give you some ideas.
-Jimmy.
Edited by -Jimmy-
  • 3 weeks later...
I have a Nismo GT Pro 2-way.. harsh, clunky, noisy, super predictable. I love it :D
It's not for everyone though.
got the same one. I love it!! Even though people ask if my car is broken all the time when they hear it haha
Do you get mothers clutching their babies when you drive through carparks? lol
But yes, if you buy an aftermarket LSD, you just get the centre (my Nismo 2-way actually came with new halfshaft flanges, crown wheel bolts, gasket and some Nismo oil).
Because I was changing ratios when I put mine in, I sourced an S13 auto complete diff (in housing) and dropped that off along with my new centre to my diff guy. I then swapped the housing myself up at the workshop (so I still have my stock 4.3:1 geared diff/housing at home if needed in the future).
Edited by bubba
I have a Nismo GT Pro 2-way.. harsh, clunky, noisy, super predictable. I love it :cool:
I just fitted the Nismo GT Pro TT 1.5 way.
Clunky, yes but only when cold and at slow speeds around corners.
Wouldn't call it harsh, but certainly bites. I've left it on middle initial torque setting but probably should have turned it down to low for the break in.
Good thing about having an adjustable spring is, once the plates are worn , just crank up the spring a notch and off you go. Expect longer life out of it. Not many diffs have this feature.
After it's properly bed in, it's best to adjust the torque setting to suit your car and driving style.
Can't compare the difference between the viscous stock and this.
You just have a feeling of complete control as the car feels so tight.
Way more grip around corners even when wet, which surprised me. The car seems to track differently but seems to point exactly where you want it to.
Today on a quiet road, rolling slow, put it in 2nd, pressed in the clutch, booted it, dropped the clutch and she just kept straight until I ran out of road. Just a smooth wheel spin with no shudder. Could have let go of the wheel, but not very wise.
As bubba says 'super predictable'.
Absolutely love it. :D
as Jimmy said, if u swing a spaner. just drop the diff and shim it, i did it to the R200 i had in my Sil drift car, i put to of the biggest shims nissan sell in it. Made it a locker basicly. after 2 drift nights, it was free enough to not skip the inside wheel when driving round the pits at the track.
its the cheapest way out, if you want top shelf hear and to spend some cash... than go the nismo!
I got a tomei Trax advance. 2 way LSD
cluncks, chatters and likes to chew up rubber in tight corners. Not so good in carparks either, sreeches wheels and carries on. Can also be a bit of a handful in the wet too if your not on the ball, especially when boost comes in.
Bloody brilliant though, incredibly predictable and the grip is amazing!!! The difference between the stock VLSD and a proper 2 way is just huge! The predictability and grip is ten fold as good.
Its not for everyone and unless your prepared to put up with the harshness of a proper mech diff, dont get one.
Get a GTR diff. thats mech 2 way too, re-shim it with some smaller shims so as it doesnt feel "locked" and doesn't bite as hard. Best and cheapest option for a streeter id say. Bear in mind the gearing is different so the speedo will be out.
Can ask though, what are the reasons for wanting upgrade the diff? Does the car see much trackwork? Drift? etc.
One good reason for an upgrade is mine:
The stock viscous in the GTS-T isn't designed to cope with high horsepower, never mind the torque of the 3.0.
I was sideways more times than I can remember and it really gave me the sh>&%$.
Sometimes it would hold but the wheels would shudder on launch, other times the ass would flick out like a bitch. Happened really bad once at Oran Park, felt like i was going to flip over.
Having that unpredictability in the back of your head with 337 rwkw defeated the purpose of building the car.
GTR diffs are certainly a good option, however don't you have to replace the rear axles and wheel hubs to GTR also?
That'll all add up.
Got a GTR rear put in mine, yes the axles and half shafts need to be replaced, I got the whole rear replaced, was tightened up a bit but as it doubles as a streeter I didn't want it to tight, much better feel on the track with no spinning one wheel coming out of corners and very drivable on the street.
Cost around $1500 for the supply and install.
how long would you expect a shimed diff do last,
ive been told that if you change all the plates to nismo ones that it will take what ever you do to it.
i dont know if this is true or not the cost is $850 diff out, new plates, diff in drive away
yes or no
I cannot answer how longer re-shimming would last but the larger axles and shafts means they are not going to break to easy, GTR shafts look much stronger than the GTS-T ones that came out, so the extra supporting mods was why I went the whole diff swap as apposed to just the center.
Anyone got some info on this, circuit, drag stuff with grip tyres, see what happens when they are being used in high load applications.
    • Plazmaman 76mm Pro Series, done. Data to back it up, I posted up somewhere here a few years back
    • So.....wire it up appropriately. You can't use the resister pack with those injectors anyway.
    • that’s the thing i’m on ID1050s and haltech not getting power due to the injector resistor
    • ahh okay cheers, i was thinking of just going for the m073, think m079 would be way too overkill considering they are same size.
    • My first car was a HG. I'm very familiar with them. A mild cam upgrade is a good idea. The 186 is a very flexible engine - meaning it has good torque from down low. You can give up a little torque down low for quite a lot more excitement in the mid range, and a bit more up top - but they are not exactly a rev monster. You need to upgrade valve springs at the minimum. For a bigger cam, you'd want to make sure it wasn't still running the original fibre cam gear. That would be unlikely, given that most of them shat themselves in the 70s and 80s, but still within the realms of possibility. Metal cam gear required. Carbies are a huge issue. The classic upgrade was always a Holley 350, which works, but is usually pretty bad for fuel consumption. The 186S had a 2 barrel Stromberg on it that was very similar to the one on the 253, and is a reasonable thing if you can find one, and find someone to help you get it set up (which is the same issue with setting up a 350 to work nice). The more classic upgrade was twin sidedraught CD type carbs, or triples of same, or triple Webers. The XU-1 triple Webers being the best example. You can still buy all this stuff new, I think, but it's a lot of coin to drop. And then the people able to set them up are getting fewer and further in between. There's still some, but it used to be everyone's** dad and uncle could do it. **Not everyone's! But a lot. All in all, I wouldn't get too carried away with the engine. Anything you do to it without a full rebuild for power and revs will only make it slightly faster. I am all in favour of a complete teardown rebuild, with nice rods and pistons, 10 or 10.5:1 compression, and a clean port job with at least a big enough cam to run 98 with that compression, if not bigger. And if I did that to a dirty old red motor, I'd want to inject it too, which I'd struggle to fight against the devil on my shoulder that would argue for ITBs and trumpets. But the bills would start to mount up, and it will still never make stupid power. OK, a few people still know how to build absolutely mental red motors, courtesy of the work that went into HQ racing and modern knowledge being applied. But even a 300HP red motor is no match for an RB20 with a TD06. So you have to decide what it's worth to you. I'd just put a set of 6>2>1 extractors, a 2.5" exhaust and an electronic ignition conversion/dizzy on it and just run the old girl like the fairly slow old girl that she really is.
