  • Replies 200
First one is my favourite. Focus seems a little off.. I'd suggest taking a small LED torch to help camera focus when shooting at night time
P.s. Those wheels rock!
Thanks a lot for the feedback mate - noted... It was a bit rushed. The other thing was I had the ISO setting up around 640+ on my D70 and there tends to be a fair bit of noise added up towards the higher ISOs, which I hate.
Ah yeah - I've got a D80 so know what you mean!! Another tip - If you have a tripod (like the reflection shows!) just fix the ISO to 100 or 200 and just do a longer exposure to make up for it. Also try using the timer (I do it all the time) so you're not touching the camera at all when it starts the shot :happy:
Cheers Zennon. The tripod's pretty obvious hey :) I'll usually leave it on 100 by default but for some reason had jacked it up about a week earlier and didn't put it back. Haven't quite got it down as a routine yet to check it before starting a shoot. I do use a remote to set the shutter off though. I've also been looking at possibly buying a newer Nikon with a larger screen, cos even though the D70 does everything I need it to, I find the small LCD is a massive hindrance to checking for focus, noise, etc before going back to the laptop.
my remote shutter/hold switch I bought on ebay for $5 incl postage was probably the best accessory I got for my D90. No shake, easy to use on tripod, lets me set up the camera and then stand away from it while taking pics... which is great when you don't want to startle animals etc. Awesome for macro photos.
Nagoodness - cheers dude :) Will do a proper shoot of the car soon. Been so busy lately and also very lazy hahah. Car needs a good wash!! oh and i like your 2nd last shot of that chick (its cute).
godzilla - i took that shot at my work carpark. So you wont be able to do it there sorry :happy:
akw - WOW thats crazy!!! nice shots tho :)
lepper- 1st and 2nd shots for me ;)
As for ISO - yeah I did that once! Took photo's for an hour before I realised I had ISO on 3200 from some testing last time!!
As for screen for seeing OOF areas.. yeah you're never going to be able to buy one big enough I'm afraid - only way is to zoom in on the little screen three (or maybe 4) times and then check ;)
Yeah I've got one of those - use it for night time shooting but during the day I still find myself using the timer instead
Irfanview is good and free
Just open the photo in that and press Ctrl+R (for the resize/resample image dialog)
Then type in how many pixels you want the image to be wide e.g. 800 (leaving other settings as default) and press Enter
Then Ctrl+S to save :)
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
