ill have roughly 35k to buy another car. I was just wondering what your opinions are on purchasing either a 33 GTR or and 34 GTT.
i currently have a s2 r33 slighly modified. i would assume that if i but a GTR i wouldnt need to modify it, whereas buying a 34gtt would be pretty stock. plus the disadvantage of not going sideways or drifting in the gtr
https://www.sau.com.au/forums/topic/31522-33gtr-or-34gtt/
  • Replies 65
Tough call that one. Everyones got their preferences and as far as looks are concerned that's something you've got to decide for yourself.
On "paper" both the R33 GTR and the R34 GTT put out the same power, so there's not a lot between them in the power department.
Most people are gonna say go the GTR because, well - it's a GTR! :(
With the GTR's you'll get what is considered a stronger engine, plus the ATTESSA torque split system. You'll also be getting an older car, with higher KM's and an older design. Personally I like the feel of the R34's - they seem much smaller than the R33 series, particularly inside. R34's have the more modern interior and the updated RB engines with improved torque output over earlier RB's. Handling, well my R34 handles pretty well but I've never driven an R33 GTR at speed so I can't really compare. Both cars have HICAS, LSD's, sway bars etc and both have 17inch alloys as standard.
If drifting is what you're wanting to do, then perhaps the RWD GTT would be the wiser choice.
Probably the best advice is to test drive both and see what you think! :)
Dave
https://www.sau.com.au/forums/topic/31522-33gtr-or-34gtt/#findComment-636377
Go the GTR, GTR's hold their value, $35k will get you a good one. Youll be able to resell it for what you paid for it. Plus GTRs are the ducks guts of all cars and what all GTS, GTT etc drivers dream of.
Plus power... stock GTR eats GTT's.
Plus Grip
Plus the 11 inches of front and rear rubber (265/40/17 fit on stock wheels)
Plus watching the tail hang out at will on a skid pan and then gathering it in by pressing the loud pedal
Plus street cred as in.. "What kinda *line* ya got" "OHHH so you dont have a GTR"
(Flame proof suit on)
https://www.sau.com.au/forums/topic/31522-33gtr-or-34gtt/#findComment-636389
^^^^^ hehe I knew you guys would say that ^^^^^
They're right though. The GTR has the street cred and the instant respect that the GTT lacks. Re-sale is always going to be better for the GTR. The GTT is an absolutely fantastic car in every way, but the GTR is better. I'd be happy to own either.
https://www.sau.com.au/forums/topic/31522-33gtr-or-34gtt/#findComment-636413
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
