Once you start moving a lot of air it's worth an upgrade as the stocker can't dump the pressurised air quickly enough.
In your case i'd say it's a worthwhile upgrade. One with a big piston like the turbosmart supersonic or plumb back would do it. Or bigger.
Blow of valves are such a wate of money - not only do the increase the time to death of your turbo - they are very cost articultate.
ha ha ha ha ha ha ha ha
Go the quad BOV - way to go !
Increase the time of death? How so exactly? Costly? $200-$300 to ensure the life of the turbo and provide proper air ventilation, hardly costly.
The stock BOV will be leaking quite a lot. You said you run about 20psi. At 17psi the stock BOV will leak around 2-3psi mark. At 20psi its probably leaking 3-4psi. Check a recent trhead titled "free stock bov mod" which covers blocking the leak hole on the stock bov. Also has microtech data logs on a car running a GT2530 and 17psi. With the normal it leaks around 2-3psi. With the hole covered up (aka a new aftermarket bov) it held upto 19psi as it wasn't leaking during spooling.
Of course you could simply just cover up the leak hole. Just remember an amto bov will probably cause your car to stall when u go from low rpm + boost to idle as the air flow sensor goes nuts, not sure on exact technicals but thats what happens.
On a stock sr20det or rb20ddet,rb25det i would say an aftermarket bov is probably overkill unless you want the pschht or flutter. However with an aftermarket turbo then certain get a proper bov, you already have a proper turbo and wastegate, why not a bov.
Also the flutter will cause damage. The flutter is the air pressure go back thru the pipes and hitting the turbo compressor wheel aka compressor surge. The vl turbos do this out of the factory as they didnt come with a bov. After a gear change the pressure goes back the way it came and hits the compressor. The turbo will surge (flutter noise) and loose pressure and give some lag too as its being spun in reverse, it then its a bit more pressure to spin it back the other way and start spooling again. The bov will prevent this and stop the surging occuring, unless its a plumback crap design one :D
The flutter is what "increases the time of death" not a correctly fitted bov
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
