Was hoping to get some advise and help from some of the people on here that have built or building roll cages and know 3D Sports Sedan regulations, Have a friend looking at a EVO race car in New Zealand, car has New Zealand Motorsport Log Book with Roll Cage Homologation papers, Just want to confirm the cage would be eligible to run as 3D Sports Sedan here, Looked in the CAMS manual online but could not find much on chrome molly cages maybe i was looking in the wrong place?
Cage is made from 4130 Chrome Molly CDS
Outside Diameter : 38.2mm
Wall Thickness : 2.6mm
Yield Strength : 753Mpa
Ultimate Tensile Strength : 805MPa
Here are some images of the cage any advise or impute would be great.
Also any reason why this car would not meet 3D regulations for CAMS here, this is the what the car looks like, I know I have to check the sizes of the bonnet vents and front guard vents and make sure the rear diffuser is within specs. Think it needs head lights that work and maybe other little bitsbut would there be any major reason it could not be a sports sedan? And yes still runs the full floor pan and chassis.
Your best thing to do would be to talk to CAMS and ask if a cage certified by MSNZ is accepted here. The CroMo cages are usually done to an FIA spec that is recognised pretty much everywhere, so it may be ok. Otherwise that are some companies in Australia that will certify the cage for you.
You might be Ok with the car in that spec to run as an open class sports sedan, they have fairly liberal rules, and do not need working headlights.
CAMS allows only CDS cages based on their general designs. If it is not CDS it requires full computer simulation to confirm it meets the requirements. Or you could just paint it and say it is CDS.
There has very recently been a huge argument between CAMS/NZ/FIA regarding rally cars, which ended in CAMS rejecting the FIA/NZ approved cars. Insanity.
Duncan can you advise of some one in Sydney that will do the full computer simulation on the roll cage and do you know of anyone who has had this done with cost ect? Done a bit of google and found Rod Andrews Race Cars at Seven Hills will call him on Monday or any others?
absolutely NFI mate....everyone I have ever heard of just pretends it is CDS :blink:
maybe ask bonds. and I think the cams manual had some contacts back in the old paper days.
Bonds are the best to talk to about molly cages in sydney. Pete's done that many of them he has a very good idea of whats good enough and whats not
Its not as simple as getting an engineer to approve the design though. The paper work and evidence to cams requires MDS (material data sheets) to be provided and welding ticket from the manufacturer. As well as detailed photos etc. Its rather difficult to get a pre built molly cage done.
I have Homologation for an R32 molly cage which ive done 2 of now and the expense was not worth the outlay in my oppinion. The original cage was fully paid for by the 1st owner as well as the Homologation costs. He owns the rights to the cage Homologation, which I have his permission to use and pay him for.
Peter has Homologation for a really nice evo X molly cage and I think he may have a IX as well.
Once Homologation is complete you are able to reproduce that cage design as many times as you wish without having each car tested and the expense repeated. Just requires an inspection to ensure it meets the Homologation.
Id just be painting it and logging it as a CDS cage. Providing it fits the CAMS outlines for a basic cage you shouldnt have any problems.
Do you know the ID and OD of all the bars used??
Sorry just re read it 38.2mm so you cant do it as a CDS cage its under the minimum required.
You dont want me welding shit for you atm duncan!!!
On a side note if you are planning to bring the car in and build more evo's from it then homologation is worth the hassle.
SS guys do this with chassis all the time to reproduce and not have to pay each time.
Not sure he'd be prepared to sign his rep away on something a bit unknown, have used this guy several years back on spaceframe beaming and torsion...
engineer
If you're in NSW, for 3D eligibility matters, Lance Smith would be your man to speak to if you think something is possibly over the line, long association with ASSA, should be on the list of approved scrutineers.
If the worst does happen and the cage can't be approved, we got a few ckd Evo FIA 4130 cages for the 12hr out of Italy relatively cheaply a year or so ago...just add filler wire!
Thankyou for every ones help, spoke to Peter at Bonds today and also CAMS, car will not comply as is would need some work so not buying...
Anyone got a Nissan race car they want to sell instead????
  • 6 months later...
Thought id post my question here before starting a new thread :blink:
I’ve just received a bonds six point bolt in cage for my HR31 and am worried about the position of the diagonal bar on the main hoop.
With the cage assembled, it goes from the driver’s side bottom to the passenger side top.
Is this correct? I had a look in the CAMS manual and from the diagrams it looks like it should go the other way. Will it pass log booking like that?
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
