hey guys,
just wondering where you'z have put your batteries.. i have been thinking of it putting one under the empty dash on top of the tranny tunnel.., it will only be the bare minimum yay by yay big, room isnt an issue, the only issue thats stopping me is if its allowed there by CAMS, scrutineers etc..
what does it need in the way of isolator switches?? one inside and one outside?? or just one thats easily accessible in the way of an accident?? whats the go there??
last thing i want is to make up a neat as bracket, tidy as wiring, and then get turned away from the track because its not allowed..
im thinking something like this.. dont want a fully enclosed box, as if its under the dash... removing it will be an issue if its properly secured.
cheers
Linton
Best place is as low in the car as possible....and counter balancing the car...ie on the passenger side
But I dont like the idea of it being under the dash...sounds like it would be too hard to get too etc.
Mine is in the factory boot spot but i will move it down into the spare wheel well
For the isolator switch...CAMS needs to be able to kill the power to the car at the base of the drivers side A-pillar
the switch can be on the dash aslong as it has one one pull cables running to the spot mentioned above
thanks zebra.. i have seen one of the pull cables.. thats handy to know..
i had read about an ae86 that had the battery under the dash... i thought it might be good, out of the way, all cables can be short and neat and hidden away. no pics of it though..
with everything gone from inside the dash, there is tonnes of room in there.
id go the counter balancing route, but u also forget that the battery produces acid vapor and apart from it being bad for your lungs and smelling rotten, it can be very corrosive to any metal directly above it....
personally i would steer clear of the dash idea....and if u think a 'maintenance free' one will still work, they are the same, they still vent the gas, they still work the same way.
also iv seens batteries literally blow up due the the alternator regulator being faulty (it may never happen to u) but if it does i would not like it to happen right above my lap/legs.
Edited by TRB-001
You can get sealed batteries....like what NZM.031 has
I like phunkys setup though
phunky's set-up and the one nismoman describes is the way to go. no question. there are many reasons why nearly every race car you put your head in will have the battery there, or in the boot.
it needs to be accessible. due to the nature of the use of race cars they often need batteries charged or replaced.
you don't want it near you.
you want it low and secure.
you want it easy to wire up.
so yeah, floor, passenger side, as far back as possible is the place to put it. easy to get to but still out of the way.
under the dash, not a good idea.
if you get a lite battery it gives you some more freedom of where you can put it. I'm getting a 4.3kg battery from braile, and it's going in the passengers side of the boot, working off corner weights it should take some weight off the drivers side front (which is where alllll the weight is)
thanks everyone... and phunky... id completly missed that with a sealed battery you can lay it flat.. my thoughts were purely on normal style ones that have to be upright.. thanks a tonne for posting that pic..
thanks ben, i will be seeing the battery shop tomorrow to work out the size and battery needed... it doesnt need to do anything other than start the car really, could probably use a torch battery.. haha.
ill make up the mounting box and start the wiring.. when the time comes to corner weight it, if its better in the boot then i will move it there... it will just be a matter of running longer cables to the isolator switch.
thanks again.
Linton
just remember that an engine kill/isolater switch is required, not just a normal battery isolater switch.
Means it must switch through engine ignition so that when it is switched off the engine dies unlike with a battery isolater switch.
as in just a toggle switch like on most of the aftermarket ignition switch panel... or a battery master/isolator switch that also switches the engine circuit??
im confused now... so this is what i had thought it was..
Battery > battery isolator switch > kill switch > junction box > ignition start circuit ???
i always thought the kill switch is just like the "ON" position on your normal ignition barrel, has to be on to start then flick that switch off and the whole thing shuts down??
HAHA! no worries. All part of being a fellow motorsport enthusiast.
After I stuffed around with 2 pin isolator switches, I realised it was easier to buy the kit and do it right. It comes with instructions and is very easy to fit.
I felt better/safer knowing that if I crashed and I was out to it, then at least a marshall can easily pull the ring cable and kill the engine/ignition/battery all in one.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
