Hey guys,
I'm interested to see what people consider to be a reasonable power band; IE full boost ---> Redline, for a street car.
at the moment i make fullboost at 5.2k or a touch later and pull all the way to redline (8k), this is in a built 32 GT-R with 33 N1 turbos.
Although I already knew this was rather laggy, It was driven home to me when i was given the opportunity to drive a mates 32 with GT-SS's, the response was phenomenal.
As many of you may have seen, I have been deciding which way to go with turbo's at the moment, wanting to keep the twins configuration and the standard manifold as mine has been cleaned up i have a few options available to me.
I have decided I would not want to go smaller then the output of a pair of -5's, but it seems my knowledge of what's available is lacking, as I detect a bit of a gap in the range between -5's and -10's or GT-RS's.
Sorry for the long and convoluted wind up but my main points are this:
What is an acceptable power band for a street driven track car ?
Is there a turbo that is above the -5 and below the GT-RS/-10 ?
Would -10's/GT-RS's be too laggy or surge in my application ?
I've gotten in trouble for not posting enough detail before so the car is:
2.7L or nigh on, not a stroker.
33 N1 turbos
Built engine
light headwork
portmatched inlet manifold
trust 4" intercooler
264" Inlet and 272" Exhaust camshafts both with 10mm lift (HKS)
4" Exhaust.
Cheers,
Mitch.
Edited by Nee-san
https://www.sau.com.au/forums/topic/317551-acceptable-powerband/
GT-RS is 450rwkw+
So much more than R33 N1's will ever make. -5's will do 380-400rwkw on a good motor, GT-SS's around 330.
There are no turbos "in the middle" of any of those far as i am aware.
Yeah, i thought it a little strange that nothing sort of falls into that gap...
anyway, what do you think about useable powerband ? the power of the GT-RS's is rather appealing but if im only reving it to around 8500 RPM will i have enough room to use it ?
The -5's really do look quite good its just that in the dyno thread ive seen a fair few setups fall short of the 420+KW im looking for.
If it helps, the car will be spending probably 80% of its track life at Queensland raceway.....
Thanks for the reply mate,
Mitch.
One thing I can say.....R32 and R33 N1 turbos are about the worst thing on the market for response. Any modern, ball bearing turbo will make the same power 1500rpm sooner....or far more power at the same revs if you go larger
Agreed, this is why im tossing up really, since as Ash has pointed out there is really no middle ground, GT-RS's or -5's for around queensland raceway it all comes down to which one....
I'm just not sure of the Pros or Cons each way as i havent personally worked with either of these turbos.
Cheers,
Mitch.
a car that makes 380 on song by say 4000 revs should be faster around a track and more fun that a car that makes 420 by 5000 revs
personally i would be looking at possibly dropping your power level a tad and shooting for some response.
you could also go a twinscroll single setup...
There are a few that go around QR on here with power between 370rwkw & 440rwkw...
Hopefully one of them can pass a bit more experienced comment :ermm:
Given you can get 400rwkw from -5's on a solid motor... it's only 20rwkw shy of what you "want" which is pretty close IMO
Thank you for this post Duncan, i just saved myself from spending $1200 on R33 N1s
GT-SS would be the way to go if i was to upgrade when the stockers let go.
Also, how would you tell if the turbos came from a R32/R33/R34 ?
What middle ground are you looking for?
As ash said, one option is about 330kw, the next finishes around 400kw, the next goes up around 450kw.
It's not like garrett will make bolt on turbos that suit 330kw, then a new set for 350kw, then a new set for 370kw, then a new set for 390kw, then a new set for 410kw etc
it may be worth going to QR when you know skylines will be there and just asking people in the pits :ermm:
I think -5's or -9's. Its torque and response out of the corners that make for a quick track car. Its the reason why the EVO's still kick many the GTR ass at track days. Lighter weight cars, plus also more respnse out of the corners.
If your racing a fast track though and are achiving 250Km/h+ on the straights then GTRS's and more power is worth considering so you can make up some time on the straights and sacrifice some out of the corner response (and stability).
Its been my limited experience that most of the time less powerful cars are easier to drive smoother around a track, and as a result produce lower lap times.
T517z's are good for 360rwkw @ 20psi on my car... usable power from 4000 - 8500... there's your middle ground;)
dunno if you've got E85 up there but -5's with some E85 should get you over 400rwkw... heaps of power for track work IMO
Ive been in your car, before you owned it.
What a machine that thing is!
OP: As said, its up to you to find the amount of lag you're happy to put up with in the conditions you drive it in. Mine is between 3500/4000 and 8500rpm for HKS GTRS's although a 3L bottom end, that suits me, may not suit others. It would be a good idea to look through the dyno result threads in this section aswel, some decent info in there (aswel as a lot of crap results)
i wonder what would happen if given a laggy powerband you change diff gears instead
does it make the car complete ass to drive or does it reasonablly shift it lower, ie more response
the evo specs reference 4.3 and 4.5 final drive vs GTR/GTST 4.11
There's someone on this board, who i doubt will see this thread, but has recently taken out a 6 speed box and put the stock 5 speed back in.
The car was pretty responsive (given its huge single turbo) and now is just all lag.
I can't imagine what another 100rwkw with the same (if not better) response would be like... but if I'm ever in NSW I'm coming round to find out! lol
I'm keen to try E85 next... figure as far as bang for buck at this point nothing can beat it
edit: yeah Paul the Mines 34GTR runs shorter diff ratios... I'm keen to try the GTS4 diffs, they are about 4.3 from memory... can't hurt the cruising speed that much, I hardly ever use 5th gear as with the big cams it runs more efficiently cruising at 3,500 - 4,000 rpm... you can hear its actually quieter at that rpm too which took some getting used to, looking down and seeing 4k on the tacho makes you want to shift up
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
