Anyone knows of some good towies that do regular runs from the 'gong to Sydney? The towie I used to use no longer tow cars but only heavy machinery.
Or...does Kiwicar still do what they used to do ie sends the car to Brisvegas and they'll help out with trucking it down to Sydney? Port Kembla is just a major PITA when it's used to be nice and easy at Glebe Island.
Thanks fellas.
https://www.sau.com.au/forums/topic/317963-shipping-to-port-kembla/
Ring Kirrawee Towing and ask for Stratty 9521 2300. Yes Port Kembla is a right pain, and towing seems to cost a fortune. I actually send most of my cars through Brisbane - it's cheaper to transport them from there through Kiwi than to get them towed from Port Kembla. Go figure...
i should invest in a car trailer and do port kembla --> syd runs for extra cash :D i live bout 5mins away from port kembla car port.
^^^this strategy (via trailer hire) would certainly reduce the cost of a double-run by a professional driver.
if you add up all your costs and also your time, it would work out cheaper to get a professional tow... :)
yep precisely! it's actually not that bad. tow should be around $250 for a 'retail' customer from port kembla wharf to sydney cbd and a bit less if you are in the trade or have a good relationship with your chosen towie. for the hassle of paying $120 for a trailer for a day, plus needing a car to tow it with (another $80+ if you don't have one), then add the drive down, the drive back home, then the drives to pick-up and return the trailer, all the fuel you use and the half a day minimum this will all take and all of a sudden $250 for it to be delivered to your door or workshop of choice seems pretty bloody reasonable.
most towies with a proper tilt tray wont get out of bed for less than $150 anyway so $250 for such a distance seems pretty fair.
iron chef, I would always advise shipping to the port the car is going to. kiwi are bar stewards. for all the extra time and extra risk to the car I say ship direct to sydney and try a towie like select. if you explain you are a broker and can provide regular business they should do you a reasonable price. much more convenient I reckon.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
