  • Replies 49
Jai you cant talk. The video evidence in regards to your driving speaks for itself.
"Jai jai, jai of the jungle, watch out for that tree!" *WHAM!*
You seemed blissfully unaware of your surroundings as you slammed into a tree you didnt think was there. Who'd have thought there'd be trees in a forest.
Red17
https://www.sau.com.au/forums/topic/3184-yellow-r32/page/2/#findComment-438304
Black MX-5 sounds like Chris's Mazda Factory Turbo "SP" but they don't have a huge IC.
Perhaps it was Leslie's MX52NV, he also owns a go fast bits shop called Wheelspin.
I'm always keen to see more turbo/supercharged MX-5's around Perth so hopefully there's a new one in town.
I think that yellow skyline is one of my neighbours, don't bag someone because they didn't try and run you at the lights. Not everyone is a highway hero.
I beat GTRs all the time when they're not trying or they're parked.
https://www.sau.com.au/forums/topic/3184-yellow-r32/page/2/#findComment-438445
Red17
Take your car out on a rally track then, and go all out, and then tell me what happens. You dont have the stones to try, do you? Didnt think so. Tosser.
https://www.sau.com.au/forums/topic/3184-yellow-r32/page/2/#findComment-438575
  • 9 months later...
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
