  • Replies 103
sniffing around that short shifter!
That's what she said :(
where exactly is this over representation taking place?
and your complaing why?
Also curious as to where this over representation of skinny blonde skyline drivers are?
Because fucking a skinny blonde is like fucking a tool chest:
They're both easy boxes to get into
They're both dirty and you really need to wash for a while when you finish
All your friends have used them at some point (and possibly your dad)
It's quite easy to drop something in without hitting the sides
And they both have the same IQ.
By the way: you're* - Learn to English.
f**kin lol John. Almost as good as the Wii-mote.
Oh and Hi Lizzy you probably won't read this thread again but ahwell.
Tits or GTFO?
I know :blink:
Why can't we have some curvy brunette gals? Not your kind of internet porn star curvy boz... I'm thinking maximum size being along the lines of Megan Mullally. A happy medium, if you will.
Megan Mullally I think not, I cant stand that woman and shes not a looker imo either.
Let me refer you to some attractive curvy brunettes
Penelope Cruz
Ashley Judd
Because f**king a skinny blonde is like f**king a tool chest:
shit john... everyone has to have a go on the town bicycle.. at least once..
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
