I think poor lizzy has been scared off,what a shame,we need more girlies here. :D
yes its appauling.
have you douchebags learnt nothing? when a new girl intro's herself, we should at least take it slow, let her get comfy, maybe have (OO)SKYLINE(OO) do the intial greeting, as he's always polite and shit (extra points for you), and then once they start to realise what twisted fkrs you all are, you may procced to the boobs, snatch, pics or gtfo comments.
so in summary, around half way through page 2 should be sufficient!
  • Replies 103
You mean dangle a deep friend double quarter pounder in front of them and see if they pounce?
I just got an image in my head of Boz hanging out outside maccas with a Big Mac on a string which he drags along the pavement to lead the BBW's to his Flatbed to get them home with him :D
lulz PJ, but really ladies you need to harden up for internetz sake.
We really are a bunch of really really really great and awesome gaiz.........
.....well I am.
so is Ash,
dun ban me brutha
hay people the names lizzy , new to the site.
im from the parramatta region & drive a R32. i did drive a r33 before but it was an NA so now ive kicked off the P's and onto the real thing.
hoping to meet other like minded people who have an interest in japo cars. ther also arent that many girls i know who have import cars so it would be nice to meet new people as well.
any questions... i guess, you can ask me!!
Lizzy xxx :(
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
