  • 3 months later...
all rb + rd diesel + N1 and Tomie blocks are the same as highlighted area on the left pic - series 1 n/a rb30 - written by nipzo block to use. but right pic - series 2 vl block different has stud plates fitted maybe strong or weaker , trying to figure out
  • 2 months later...
This is my exact build. Had a junker manifold and a .59 (!!!) housing and dynoed at 370 whp run in tune. Didn't get to dyno it after I added the true divided twin gate 6boost. Very responsive on my run in tune. If you tune it well you will be very happy. I have a feeling however, that the exhaust wheel will become the limiting factor. It is just too small. It seems better results may be had with the 6266.
This is my opinion.
Anyone got a precision billet turbo on there 30? Looking at the 6262 journal bearing with .82 rear.
Can someone please do me a kindness and post the part numbers for King Bearings RB30 main and big end STD spec bearings. ACL is out until the end of summer. Jeez. I for the life of me cannot seem to nail them down. Kings webpage is pretty convoluted :/.
Thanks in advance.
Edited by ST240
  • 2 months later...
hi guys I have a rb30 series 2 motor in my vl commodore and am wanting to turbo it just wondering what advice people can give me on what to do and where to get the parts from im doing it to a budget so any help would be great thanks :no:
I would recommend trying the Calias turbo forum. they would be your best source of info mate.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
