Ladies/Gents,
parked my GTR in rundle st upark last nite. it was only there for bout 30 mins returned to find it badged. both front and back. pulled the entire block mounted front one off, breaking clips to. the rear one they have scratched the hell out of the boot.
Does anyone know any good touch up guys??
doesnt this sort of inane bullshit just stink?
thank dan
https://www.sau.com.au/forums/topic/318813-badged/
Damn that sucks, use to park my line there fairly regular, no one obviously likes the little GT bagdes that much.
What the hell do these wankers do with a pair of GT-R badges anyway? Stick them on their commo so it's 'fully sick'
Edited by J_Red33
https://www.sau.com.au/forums/topic/318813-badged/#findComment-5209294
I got mine de-badged a few yrs back, lucky the guy was a pro, no damage to the paint
You can get a genuine one from Nissan for about $60-80
https://www.sau.com.au/forums/topic/318813-badged/#findComment-5209319
dam thieves
try Jason, Chips and Dents
0411731973
i haven't actually used him but he was very nice and dropped by to give me a quote, i think Justin @ Everlast referred him to me
Second Jason Kane from A1 Chips and Scratches. Had his side kick out to work last week to respray and re move all gauges ect from lower lip in the stag :rofl:
https://www.sau.com.au/forums/topic/318813-badged/#findComment-5209346
friend of mine has a 32 GTR. He had the badges stuck on with industrial strength velcro and then whenever he parked somewhere in town etc he just pulled them off and put them in the car. You couldn't tell if you looked at them that they were only stuck on.
He went out the other week though and forgot to remove the badges first. Got back to his car and they were gone :( I guess the only upside is that the paint wasn't damaged.
https://www.sau.com.au/forums/topic/318813-badged/#findComment-5209703
It’s a real shame that people do these sort of things and velcro has to be used so badges can be removed when parking your car :)
https://www.sau.com.au/forums/topic/318813-badged/#findComment-5210120
Someone who works at the same place as my mum bought an Aus delivered R32 GTR back in 1992, he said he couldnt take it anywhere, badged, scratched, damaged etc. Bogans must have been a bit more upset back then than they are now...
Sucks to hear though, hopefully it doesnt cost too much to get it back the way it was!
https://www.sau.com.au/forums/topic/318813-badged/#findComment-5210353
Heheh. Aside from the GTR badge on the back, the rest of my badges have been removed prior to the last respray
just hope no mongrel keys it
-D
https://www.sau.com.au/forums/topic/318813-badged/#findComment-5210852
twas 140 for a r32 gtr badge when i spoke to them, that was few years ago though. i think 32s is the only 1s that have specific badges for specific colours because the sticky bit behind needs to match your car. lol just noticed u got 33 so prob cheaper for urs then :)
and as for what they do with them i dont know, but i usually get pretty mad when i see a fake gtr with a badge present thinking is that mine you lil f er
Edited by Inline 6
https://www.sau.com.au/forums/topic/318813-badged/#findComment-5210998
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity.
    • 100% the factory sender is tapered, that is how it seals (well, that and teflon paste or tape)
    • Thanks folks - I've saved a few links and I'll have to think of potential cable/adapters/buying fittings. First step will be seeing if I can turn the curren abortion of a port into something usable, then get all BSPT'y on it. I did attempt to look at the OEM sender male end to see if it IS tapered because as mentioned you should be able to tell by looking at it... well, I don't know if I can. If I had to guess it looks like *maybe* 0.25 of a mm skinnier at the bottom of the thread compared to where the thread starts. So if it is tapered it's pretty slight - Or all the examples of BSPT vs BSPP are exaggerated for effect in their taper size.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
