thought this was gonna be interesting but half the banter on here is sr vs rb, seems like u just posted a new thread up on nissansilvia.com
i say a better engine is a 308 and you should change series to suit ( ok i lie )
info to back up my statement goes 'here'
now would the rest of the haters keep this to RB20DE discussion ONLY
  • Replies 75
Hmm, even though I'd love to have a go at it, the more people I discuss this with, the more it seems like an SR would be a better choice though.
An SR20VE out of the box, no mods will make ~150kw at the flywheel, and it will take alot of work to get the RB to that level.
That's the other big issue... it really is an unknown with the RB, because so few people have bothered.
yeah that is the thing. to get the rb to the level of a stock sr20ve is going to take a decent amount of work (not massive amounts, but not just exhaust and air filter). the sr20ve might be a bit more highly strung to start with, but unless you spend thousands and thousands on either motor to get them to their absolute limit you won't know which motor will give the best results. so for a minimal budget the sr20ve is going to be the better base to start with, since it already has 35kw more to start with.
  • 3 months later...
Everytime the same :) so many threads without any useful information... if you want to tell him, that RB20 N/A power is a bad idea, why not write ONE reply. No one is interested in reading thousands of replies with the same text/info again and again... and again.
Differences in oil pumps of the SR20 and RB20 - take a look:
Picture shows the differences of the stock RB26 (top) and the N1 (bottom) pump. N1 = advanced design, not only concerning the housing, but also the cavities of the pump gears (they can be made by wire eroding). RB20 is similar to the RB26 stock design, SR20 looks more like the N1 pump.
If you want to upgrade the oil pump of the RB20, you'd have to make one or purchase an external pump like the dry sump ones.
Valvetrain:
The RB20 has a better valvetrain design when it comes to racing (high revs). Rocker arms (SR20) aren't comparable to directly acutated bucket tappets (RB). Every part in the valvetrain can represent a spring if the revs and therefore velocity and acceleration are high enough - so every rocker arm acts like a hard spring (means: harmonics and maybe cracks) . Furthermore the bucket tappets are rotated by the camshaft to reduce wear! Hydraulics have to be removed from both engine's valvetrains.
Variable valvetrains (with variable lift) are very difficult to integrate into a bucket tappet, that's why most cars with VVT use rocker arms. I think Porsche tried BTs and VVT some time ago... But a VVT doesn't matter in typical racing applications - or do you want to drive the car sometimes in the 3000rpm range and then rev the sh*t out of it up to 9000?
Bore and stroke:
69.7mm is very short stroked. Don't know why Nissan built such an engine, but when you compare it to the SR20 (86mm) and think about the average piston speed (let's say we limit it to 25m/s) then the RB20 has a lot more rpm and power potential! -> 10800 compared to 8700rpm. Ok, this is only theory, but it's possible and it's important to know. And :( don't tell me about the squeezed SR20s driving around at drag or drift events...
So much for that.
  • 2 months later...
Was the neo engine VCT equipped? If so that would be the best base to begin with. Concentrate on headwork & flow, solid lifters, and a highly balanced bottom end to take advantage of high rpm's. Adapt some ITB's, and a clever extractor design. I guess there's many possible options, it all comes down to budget in the end i think.
Valvetrain:
Bore and stroke:
69.7mm is very short stroked. Don't know why Nissan built such an engine, but when you compare it to the SR20 (86mm) and think about the average piston speed (let's say we limit it to 25m/s) then the RB20 has a lot more rpm and power potential! -> 10800 compared to 8700rpm. Ok, this is only theory, but it's possible and it's important to know. And :) don't tell me about the squeezed SR20s driving around at drag or drift events...
So much for that.
thats all very well, but Rb20 inlet ports flow all of about 120-130cfm...So Fark all, even heavily ported you would be lucky to make over 200 genuine horsepower at the flywheel, where as Sr20 that figure comes in the Autech S15 road car, with nothing but a bit of compression and some cams.
This is a valid point that a lot of people seem to be missing in this thread when talking about the VVL in the SR20VE.
  • 5 months later...
Unless you have 150 different gears in your gearbox there will be corners where you will be in the 3000-3500rpm range
I think every car has gear ratios which make it possible to shift down whilst driving in the 3000-3500rpm range - i've never seen a car with more than 3000rpm difference between - let's say - the second and third gear.
Please keep in mind, that there are 6 pistons.
What i've found (cfm):
SR20 - 205-245 stock, up to 275 ported (x4 -> 1100 cfm, example)
RB20 - ? stock, up to 240 ported (x6 -> 1440 cfm, look here)
Build a sr20ve
Use the p12 head and not the p11 head.
your already at over 200hp. they come std like that.
The p12 is the one that come sout in the latest primera they made
Yes you can make them run in a rwd configuration. We did it on the jpp 180sx.
The head on an sr20 can not be ported to flow as well as a stock p12 sr20ve (p12)
Common shaft for the rockers so you will not beable to do a sr20 rocker flying off thing.
The one we peaked hp at 8800.
You will have the light weight of the sr20 and it will all be behind the front axle the car will handle alot better and also go alot faster due to the lighter weight.
its a no brainer
  • 9 years later...
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
