DECA is on again
As always, the event wont go ahead unless we get enough people to help out on the day.
So we are calling for your assistance - if your willing to help, or if your bringing a friend/missus who's willing to help - please speak up.
We can explain what you need to do if you haven't done it before, so don't stress about that.
It is VERY easy stuff! and you will get a great view of the action!!
All officials will be given a free lunch and water during the day.
We also need all officials to be at DECA by 8.00am on Saturday morning - same time as competitors.
I suggest you bring a chair, sunscreen, hat etc
Morning
Long Wang (5 needed if possible)
Starter - Bec
Finisher/Timer (2) -
Flaggy 1 - Anna
Flaggy 2 -
Mini Wang (3 needed if possible)
Starter - Daniel
Skidpan
Timer/Time Recorder - Tim
Starter/Hat Removalist - Campbell
Afternoon
Skidpan
Timer 1 -
Timer 2 -
Time Recorder - Anna
Hat Removalist - Grant
Hat Removalist -
See you all there!!!!
https://www.sau.com.au/forums/topic/319242-deca-volunteers/
Come on people let us know if you have mates or partners comming along.
We need these spots filled otherwise the day can't go ahead...
If we haven't got people on the day to do these jobs, we will be sending everyone home and the event will be canceled. (Without refunds)
So if you are driving make sure you get some friends to come along and help out!
https://www.sau.com.au/forums/topic/319242-deca-volunteers/#findComment-5239714
you did too sorry, had forget about that...
I've put you on the skidpan in the Arvo for now, we might be able to come up with something else to do.
Will just need to chat to the others.
Cheers
No worries, may try to talk my friend into volunteering also (depends on if he can take a sickie at work).
What is 'Finisher/Timer' by the way?
Cheers
Grant
https://www.sau.com.au/forums/topic/319242-deca-volunteers/#findComment-5240601
Timer holds the stop watch and records the times, finisher I think removes and replaces the cone in the finishing boxes.
Since Brad has just pulled out I might try to get him and his GF to time/finish on one of the wangs. I'll speak to them tomorrow.
https://www.sau.com.au/forums/topic/319242-deca-volunteers/#findComment-5244174
i still have no idea which of my mates are even coming as yet, but i'll remind them they should help out, or possibly get a kick in the crotch.
i plan to drive this time, hurting myself before deca is not a option.
https://www.sau.com.au/forums/topic/319242-deca-volunteers/#findComment-5247197
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
