Couldnt sleep.... i'm getting my first car today a Jet Black M Spec R33 GTS25t
The paperwork has been done, name transfer etc all I have to do today is drive it out the yard.....
Awaiting the 6 cylinders beating under my feet and the boost that i can control! muhahaha
*Edit* It has 18" Shadow Chrome "DTM" wheels too
https://www.sau.com.au/forums/topic/31933-picking-up-my-first-car-today/
  • Replies 47
Nice one ! You are some lucky dood to be able to get such a nice car for your first one. My first car was a 1972 Honda Civic !
Look after it man - Don't drive like a maniac on the street - save it for the track !
Post pics when you get it !
Congratulations !
PS - Come to some of the SAU events like the Advanced Driver Training, and learn to be a Skyline Driver and not just a Skyline Owner :)
Boostd - was that you at UAS the other day - you came in and talked to John about your car etc ???
I was the one fixing up their (UAS) internet connection (out of the goodness of my heart) (me = Fat ugly bastard that John kept asking questions and bragging about how good my car is now that they have rebuilt it he he he he)
It's all makes sense now ! I think !
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
