  • Replies 169
Posted Images
Landscribble, Davyboy pulled out first so you have his spot.
Hank, if you cant make it for certain, there is 1 spot remaining.
First in first served...i wont be on here until later in the morning so best just rock up and try your luck.
Definitely pulled out. My spot is available.
Not doing the day running two spacers at the front and two different width/offset wheels on the back. What a horrible day I've had!
Is anyone actually going? So many people have pulled out!!
Unbelievably, my car is still running... My cars never run this late the bight before AHG! I may actually make it, fivers crossed...
James, I always bring my camera dude!!
    • Noice. Congrats on the big day too!   don’t forget to never eat in the Skyline 🤣
    • Overnight parts from Amazon, let's go. Replaced nearly every o-rings, minus 2x from the pumps. Seems the kit is short? Then again when I replaced the main pump a few years back it did come with new seals so we are good. Yiewwww, ready for legal stimulants.
    • I'm only really familiar with the R33 setup, the factory filter is very much an encourage fuel pick up thingo.  The factory pump sits about half way down into the tank and the sock runs down into the bottom of the tank.  Mounting an aftermarket pump in the factory location with the typical tiny Walbro filter, I had huge fuel surge issues once the fuel level dropped below 50%.
    • Hi Gent, Got my r34 GTT 1999 ,wondering if anyone has a stock airbox with snorkel? currenly it has a pod filter which im planning to remove and install the stock part, as this needs to go to vic road for inspection. Appreciate your assistance.
    • Yeah, I still dunno. The size of the sock should only matter if it is blocked. It is, after all, a filter rather than a "thing to encourage fuel pickup". He has modded the original so that it is now down on the floor, so it's not physically the same as in the original complaint, yet does the same thing. I therefore lean to the problem being somewhere else. Sticking some dynomat on there is a worthwhile experiment, but I'd put $10 on it not fixing the problem.
