i lost my licence 6 months ago and have spent that time working on my r32 gtst. just thought id get some feedback on the work cheers james.
HKS GTRS lolw mount turbo
HKS full super drager exhaust
custom screamer pipe
JJR intercooler
custom oil catch can
custom air defuser
3'' induction into front bar with pod for the track
polished head
front strut bar
rear strut bar
potenza springs and shocks front and rear street setting
custom heat shield
Gizzmo II ibc boost contoller
apexi rev speed lap meter
custom glove box gauge set up boost and volt
led speedo
GTR seats
i dont know what else the list goes on just check out the pics
car recently ran on the dyno putting out 241.3rwkw at 16psi .
james !
very nice.
Is the HKS GTRS direct bolt-on to the dump? When does full boost come in?
Also where you get those steel hoses for the catchcan
imo the airpod isnt in the best place. One bad downpour and its gonna be soaked.
very nice.
yeah that was the best thing about the turbo. direct bolt up with an rb20-rb25 rear flange.
it comes on boost at about 3000rpm very responsive and skids 1st 2nd 3rd into 4th . full boost at about 5500 6500 rpm and pulls into the red , kicks like a horse lol.
i got the steel hoses from bunnings of all places in the plumbing department. im a plumber and they are the exact same hoses that autobarn and enzo fitting stock. and they look great.
cost like $15 each.
i only run the pod in hot weather when theres no chance of rain .
glad you like it dude .
cost like $15 each.
hmmm you are tempting me to swap to gtrs with those power gains.
How much did it set you back? Im sure its more than capable of running past 16psi?
Get us a better photo of the hoses, im thinking of replacing mine haha
when i got the car it came with the turbo just wasnt installed. iv research the kit tho i think its work about $2500 but im sure you can do better on eba or reco. even research the power out put of the RS kit and go to a turbo sales and get the lesser expensive brand thats rated the same just a thought.
if you do get an RS , you can run more then 16psi. i run 18 round town with 20 high boost electric duel solinoid.
heres a couple of pics of the lines .
You loose your liscence so then you spend the next 6 months making it quicker LMAO that is gold!
All jokes aside nice looking car, with decent mods. Its going to be hard to behave now lol
i see nothing wrong with what he has done
i currently have no licence for 6 months and have 30grand worth of parts going onto my car in the next few weeks lol
Great build exact same scenario with me lost mine for a year and went nuts changing things will have my license back in a month, gota make the most of losing your license now that I look at the car losing my license seemed worth it ahahah
GT35's aren't laggy.... maybe on a 2lt but they scream on a 2.5 :P
Yes they are... even the GT30 are laggy. You realise when you go back to stocker just how laggy they really are. Even hiflow is laggy but much better compare to GT's i had.
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
