also adding to listing:
genuine blitz 100mm cooler, used condition, no leaks or anything like that, 3" outlets, comes with GTR mounts for rails. $450
Genuine Greddy RB25 forward facing inlet plenum. $800
Nismo 740cc sidefeed injectors $800
Alloy R32 radiator $200
RB25det. rebuilt 4 months ago, 160psi compression across all 6. complete long motor $1500
KKR 430 turbo, no shaft play, works well. comes with vband dump, actuator etc $500
can do a package on the rb25 with greddy inlet, injectors, stock coilpacks (or splitfires), kkr430 etc. all working well in my s14 atm
also
GTR 27mm SELBYS front sway bar, adjustable, solid. $250
GTR 24mm (i think) SELBYS rear sway bar, adjustable, solid. $250
Panasport G7 rims, 17x9, gtr offset, will confirm when tires are off. $1000 set.
autometer sport comp monstor tacho with shift light. $150
gtr reo holes cut for n1 vents, but in tact overall. good nick. $120
  • Replies 50
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
