Atr43ss-2 Prototype Initial Tune 250rwkws 18psi<2500rpm, Stupidly Responsive
  • Replies 118
Posted Images
Here's the link of the video footage:
On road for normal driving its good, feels like always on boost. Once floored just wheel spin every where. 2nd Gear wheel spin from 3500RPM all the way to 7000RPM. Good responsive street turbo.
To bolton to stock setup need 2x slicon hoses, Exhaust and manifold plus lines bolton, can be high flowed into stock turbo.
Car's got 800cc injectors, Z32 AFM, FMIC, Exhaust, Clutch, BOV, Nistune chip.
what can you put together for a VL Berlina turbo that will bolt on...lines mani etc.
mint car that needs to look absolutely unmodified.
pm or post here.
Edited by Swiper the Fox
the boost looks like it drops down to around 14.5psi from 18psi ..... if you could some how get it holding 18psi to redline, im sure it would make more power....
also notced youve lost a bit of the bottom of the graph.... would love to see the bottom end of the power curve
What's special about this compared to ur normal ATR43?? what's different about it?
Yeah im curious about specs of this turbo aswell, what makes it so special to spool up and be on boost that early and that hard, yet still make allright top end?
Edited by PM-R33
This turbo was engineered for max street driving ability. Its more of a independent turbo that has no shared features to all other ATR43 models.
We've also done some testing on it using different actuators and settings with wastegate controller. I will discuss that in my thread lateron this evening.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
