Fair enough
I no each car is different i was hoping to help you and others further just need base figures to work with
but never mind thanks anyway
All good!
As mentioned in PM, im pretty sure im at my upper limit RE: SAFC tune. As from that point on, no matter what we did with timing/airflow adjustments, it never got any better. Seemed to be the sweet spot. And id rather fiddle with it on the dyno if you were to forward a bit of info. And i wont be spending any more on it untill i can afford /ask the mrs if its ok/etc etc, to buy a G4 :D
GotRice? is all about the US imports :blush:
So you're going to skip the GTSLink idea?
Te he he. Too Troo!
Not entirely... maybe just a G4 GTS link :D If i go with what Keith said, getting the later one would be a better way to go.
Speaking of.. can he get them?
Fair enough
If you're in Sydney, I can have a play with your SAFC for free and get the A/F to what you want. I used to run the older SAFC in my 180SX.
But saying that, I've hopped on the band wagon and am running a power FC
Its cool mate thank you but my cars not even in the country.
I have info given to me from Apexi regarding settings for different states of tune plus other setting from other cars set up on dyno
I just thought i could help but its all sorted via pm
Thanks
I would say speak to Dan first. Adrian is going G4, as well as possibly others :D There could end up being a group buy, so don't go running off without consulting TLR HQ.
I am quietly horrified at peoples reliance on S-AFCs, and even more so the whole "Base numbers to work from" concept. If someone made a robotic arm designed to give cut-throat shaves, but having it hard coded to suit the face of the guy who created it - a base to work with as most people have roughly the same looking face... would you use it?
Much the same thing, except your engine is the one who gets pwnt.
something to start with would be simple bending the signal around 5% under full load if you have a standard ecu with more boost. but if you cant figure that much out for yourself you really shouldnt be playing with it
So you're saying do this regardless of knock or AFRs? And you're saying who shouldn't really be playing with it...?
5% is no where near enough to make it too lean when running higher boost. standard ecu AFR's dip into the 10s under full load most of the time, even if it was holding 11.5:1 5% correction would bring it up to 12:1. even 12.5:1 isnt gonna hurt a standard motor. same goes for timing, 5% would move it up 1 row tops, worst case scenario you'll end up in knock maps which barely have enough timing to run, let alone knock.
of couse you'd atleast use premium if you were going to do it.
Did you read my posts?????
Edited by jjskyline79
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
