hey can anyone help me? i need to find out how to bypass or completely get rid of (preferably get rid of) my airflow sensor in my R33.
i am on a tight budget so if there is a cheap way that would be awesome if not it would be great to know, it has to be done.
thanks :P
https://www.sau.com.au/forums/topic/320129-bypassing-air-flow-sensor/
well you could simply unplug it. just don't plan on having a very good idle or being able to rev the car above about 2500rpm.
other than that, expect to pay a few thousand as said above.
maybe you should tell us why you need to get rid of it so we can give you other suggestions. if you are hitting the airflow cut (rich and retard) then something like a nistune will solve the problem, but will still cost you up to around $1000
thanks and i know it would run like shit if i just unplugged it, thats why i haven't. it is just in the way i can barely get my filter on the
end of it. and i know how to bypass and add in another air filter that doesn't run through the sensor. i know that helps with getting
more air through just have to tweak the sensor a little pretty simple but this leaves me with the problem of space and not being able
to fit my filter in. and while i'm asking is there any real difference in types of after market pod filters. thanks agin for your help(all)
^ ye... a bit odd. Just mod the piping. Removing the AFM as i said before, will cost 2k minimum.
Use the factory airbox, a pod is pointless on it's own anyway mate.
Just sell it and put it down as a lesson learned.
WTF, just mod the intake pipe so it suits the air flow meter and you pod filter, easy!
true huh damn :3some: i'm an idiot at times i never even thought of that cheers dude. its always the most simple thing that slip the mind when trying to think
oh a pod is not the only thing done to my car. and i'm pretty sure i need it
Depends what mods you have...
But from what I gather (by reading your sort of post) is your engine is not modified. The stock air box will be more than capable.
Probably best note down your modifications and people can help you better on deciding on the next step.
[/quote
3" 1/2 exhaust turbo back, split fire coil packs, t4 turbo, greddy inter cooler, boost controller, pod filter, so is this a non modified car? whats a modified one like?
im just not fully up there with everything to do with cars thats why i'm asking for help so i can learn.
Cool. Stock airbox is up to the task. :) Your current setup isn't too bad.
Your current setup doesn't need map based system - the gains will be very minimal vs cost.
Best spend the money on a dyno tune/re-map - you will be surprised how much more power you get - the car will still be very streetable. IMHO
It will also give less excuse for the boys in blue to dong you as hard - just remember to hide your boost controller :3some:
Changing to a MAP based system (ECU etc.) will probably only benefit if you are going to go for much more power - which will mean larger injectors, cams, list goes on.... which unfortunately means more $ to spend.
Since you are on a budget, a re-map is probably going to be the best bang for buck upgrade with your current setup.
^ Yep, factory airbox is still more than adequate and more beneficial if the POD is not enclosed and CAI employed.
Open pod + engine bay = worse than the airbox = worse performance.
i have a custom built air box surrounding my pod filter it is made of sandwich plate aluminium
so its a great insulator, and vents just above in the hood for extra coolness. thanks for the help looks
like i'm just gonna have to get a re map for now then just save save save, because i want more
power i'm greedy thanks guys i appreciate the info
I do beleive MINES still uses the stock air box on all his cars and look at the power and performance he makes from his cars. (Good enough for one of the best tuners - Good enough for me)
Pod = waste of time and attract the wrong attention.
Edited by 99 GTT
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
