Why bother when he just won't listen seriously !!!
1. Okay, first of all, I asked for opinion on weather or not the exhaust made difference, that's all i was asking in this thread... I never asked anyone to elaborate on MINES ecu. I asked "So, questions is, DOES UNBOLTING EXHAUST BEFORE CAT HELP? Please elaborate on your answers-some people say no, you need compression others say yes, better flow. ?" Where do you see anything about MINES ECU???
2. I know myself that r34 is not as good as FMIC-no shit. Only reason why im running it is because i got diked too many times.
3. I know that tuned NISTUNE is better than MINES ECU-no shit-and ill probably end up getting it in future
4. I also know that in my opinion, MINES ECU is better than stock ECU-more aggressive tune, car is faster on it with good AFRs. My choice to run it, car hasnt blown up, im happy. Stock ecu is not goona get me anything over 200kw nor run anything over 10 psi.
5. I also know im taking a risk running hiflow turbo on Mines ecu. Therefore i WILL eventually upgrade the cooler, but will have to set up stock air box. I will eventually swap Mines ecu for NISTUNE along with injectors and z32, altho this doesnt happen over night and is not cheap either.
Just thought id clear shit up.
ok to go back to the start... in theory disconnecitn the exhaust at the cat shouldnt send you backwards as all your doing is removing a restriction.
When it does come to ecu's tho, keep in mind that with a good ecu you can continue to adjust its tune with each and every change you do. so it might be worth doing the ecu first, so you can accommodate any and every mod you do as you do it.
This means that you could potentially avoid having to stump up for injectors afm etc etc all at once. and maybe even get a better more aggressive tune thats suited to your current hardware.
I had a similar set up like you 8 years ago,
Small Supra front mount, stock bov, stock turbo, jap exhaust, boost to 12psi and i ran 13.6 at Calder on a slightly wet track with sumitomo 225/45/16 but that's because my 60ft time was 1.999 something.
wow thats pretty good hey. did you take it there often, or just had a knack for it? (controlling wheelspin)
Nah,
Must have been a lucky shot but i was able to back it up with 13.8, 13.9.....etc. I didn't really launch it at all because i tried it once and almost went to the Holden VN next to me :(.
And yes i was wrong about Fuel pump making the car rich. So how am i not listening "WEST"?
Man.....
There are legal Intercoolers out there or as a matter of fact they're legal if you're running stock Air intake box, also don't cut holes for the cooler piping.
If you'd like to keep the Mine's ecu, at least get an SAFC to either en-rich or lean your A/F out, make sure it runs abit rich just to be safe. I did have a Jap Chipped ECU, nothing much really beside from letting you rev pass the limit and speed limit (this was fun watching your speedo arm going pass 180 and going back to 0 again)
Check your diff, rip a small burnout (in a control enviroment) to see if you still get 2 decent black lines at least then you'll know its still good.
When you're back at Heathcote, lower your tires pressure to at least 20psi, rip a decent burnt out and see how you go. If that still doesn't help then try to ride the clutch a bit but by doing this you'll cook it in no time.
I reckon with a decent cooler, SAFC tuned with current mods that you've got, you should be able to run at least a 13 flat or high 12.
Good luck and spray your front bar and side skirt to match will ya, if i was a cop, i'd pull you over just for that :(.
Man.....
Good luck and spray your front bar and side skirt to match will ya, if i was a cop, i'd pull you over just for that :P .
I knew all that but thanks anyway.
"When you're back at Heathcote, lower your tires pressure to at least 20psi, rip a decent burnt out and see how you go. If that still doesn't help then try to ride the clutch a bit but by doing this you'll cook it in no time."
-im going back this sunday. As for riding my clutch and "cooking it in no time", did it when i went last time, had 9 runs, and its still not cooked, maybe because its heavy duty clutch! Tires are shit, but cant really justify getting new tires yet untill i finish these...hopefully soon. (ill run them at 19 psi)
And as for my bar and sideskirts being different colour, here is the latest picture:
mate, i went and upgrade to a hks fcon pro and gained 70kw mid range. this was aided bu changing to a free-er flowing pod filter and bigger injectors and a larger front mount. very similar to your setup, ive run a 12.8 on old street tires, 14psi (low boost) and full street trim. cant see why you cant achieve the same if not better
what kind of power did you make on 14psi?
And yes, ill start off by upgrading cooler and get some decent brand tires. than ill do the nistune, and when im ready, ill finally upgrade injectors and z32.
Look man i have MINES ecu and i also have standard ecu.
You have a dyno.
-Why dont we dyno the car and see what she makes with each ecu. And ill bet you she makes more KW on MINES ECU, and that's all i was saying.
The guys are saying the standard ecu is better because it actually cares if something is going on under the hood that could kill the car.
^ 5 pages later and everyone understand this concept bar the OP it would seem...
Making power in overall terms is utterly irrelevant.
Who fken cares if a "MINES" ECU makes more power, doesn't mean it's safe by a long shot.
Man this guy is awesome, I've been treated with a couple of funny threads!!
Seriously though, what do you do when people are so stubborn, over defensive and so self righteous and sound like a prick to people trying to help him?
What do you do with answers like " I already know" or " no you are wrong" when they are the one asking for help?
Some established fact:
He loved the Mine's ecu and advocated others not to go the ecu+tuner option in his other threads/posts, he even had guys thanking him for providing such a good(cheap, they are cheap for a reason) option.
He has now come around and realised that the ecu+tuner is a better option.
This happened after ~4 pages in this thread. In the mean time, ppl tried to help him even though they obviously have no obligation to do in the first place. He shot them down when he was meant to be grateful, courteous and show people respect.
I think you could benefit from learning some manners when you are asking people to help you, have an open mind otherwise you will never learn anything fast.
Edited by s2d4
Im wondering how running the mines ecu wouldnt be as safe as the standard ecu? With standard turbo, injectors and running no more then 14psi what could go wrong?
And for a cheap option why wouldnt everyone get it for the 1st step? standard ecu not letting me run over 10psi, so mines ecu will. run 12psi which will be 5psi increase on what im running now so for 400 bucks someone tell me how your going to get a cheaper better option then that??
one thing ive noticed no one has seemed to mention throughout this thread.... is tires and suspension
im no drag queen, but i do know that shit tyres and stiff coilovers wont get you the figures you desire down the track, no matter how much power you have!
TIRES TIRES TIRES! - get good ones, not only are they gonna get you better times down the strip with better 60' times obtainable, but they are good insurance for daily driving, remember they are the only things holding you onto the road!
also what suspension do you have?
....lastly who the hell is your mechanic? because even my mum can tell you that fuel pumps dont change afr's unless the old one was dying, and she certainly wouldnt recommend putting in the old dying one because you're not happy with the extra richness!
I think the mines ignoring possible high knock levels due to the heat soaked side mount cooler and better than stock turbo.
It's mentioned earlier in the thread.
Like i said, i never asked anything about mines ecu so can we please just forget it?
Anyway, ran my car today, best time i ran was 13.35 at 108mph. 60ft was 2.23. keep in mind that i am still running shit tires which i will be replacing very very soon. had a look today, one tire is TRIANGLE, and other is DIAMONDBACK brand? wtf.
Funny enough, my mate ran his 180 sx, best he got was 13.1...ran 13.4 all day. He let me have a go in it, i ran 12.75, 60ft was 1.89. Beginners luck i guess.
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
