Tried searching, no luck
As per the title was just wondering if the length/angle etc of the intake pipe between turbo and AFM would effect the car stalling when coming to a stop at traffic lights etc etc as my car is now doing. I have heard that a longer pipe will increase turbo backpressure and help stop this. Car is not running a BOV at all, and has a top mounted turbo etc etc
Cheers
https://www.sau.com.au/forums/topic/320249-turbo-intake-pipe-length/
Yes it does matter - plus the car will not run correctly without a proper recirc BOV.
It used to run mint with standard turbo setup, generic front mount cooler kit and had a atmosphere venting bov on it though. Just since going Top mount with shorter intake pipe so thinking maybe that was the cause
I had to make mine come out about a foot, then right angle it to the airbox. Bit of ally did the job. I would like to put a few bends into it like the stock rubber intake hose, but I just dont have the room. I found a good tune will help, but only to a point.
PFC, no bov, hi mount 35r. Drives like normal. But when your on the track it can bog down when you jump on the brakes and stop quickly.
DAAAAMN U PFC DISEASE AND AIRFLOW REVERSION !!!!!!!!!!!!!
Here is a super gay fuzzy phone pic. But this length seems to work.
Edited by r33cruiser
depends, the acoustics of the pipe affect the AFM, the louder the dose/flutter/re-circulation will alter the reading of the AFM. Even going from a stock intake to a metal intake change the AFM voltage reading causes slight idle problems when backing off, but I fixed this by upping the fuel deceleration cut off to 1200rpm on the powerFC
that is a generalisation, if you adjust rows 1~3 on the fuel map this will correct over fuelling problems on deceleration. Most days I run my plumb back bov so tight there should just be a plate there instead and there's no farts/back fires or stalling issues.
Rubber piping also helps alleviate that apparently - as a random side point :(
agree with Rob and also its not the ECU's fault so dont blame that
the stock rubber intake piping is accordian style for this exact reason, so if you remove the accordian style pipework, its likely to reverse on the airflow meter hotwire
dont hate the player, hate the game
Rubber piping also helps alleviate that apparently - as a random side point :P
Now ya tell me u bum.
ah well. good for a dose :)
And rob................no, no it cant.
I did the same thing, upgraded to 3 inch intake instead of, 2.5 inch standard intake. The car was running super rich and turning off inbetween gear changes... As soon as i unblocked the blwo off valve, car was back to normal, running normal and no stalling.
Maf reversion can occur at almost any maf voltage - so you maybe able to "tune" it out at low maf voltages but unless youwant big lean holes in your tune you can't fix the issue at higher voltages via "tuning".
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
