t517z are available with two different exhaust housing sizes, 8cm2 and 10cm2. the 8cm2 are roughly equivalent to 2530s.
t618z are the equivalent of the new HKS GT-RS, and are too big for a standard capacity RB26.
As meggala said they are oil cooled only, unlike the HKS range.
The R33 i have been in with the T517Z was a very nice car, and from the passenger seat seemed very responsive. It was only running 1bar and had a crappy cat and would benefit from an OZ tuner as well.
Its funny to see how many of us rely on Zoom/HPI for out informtation, HPI say T517Z are a good turbo, so all of a sudden nice things are being said about them, when before they werent considered because they are too laggy as they werent BB and did not stack up against HKS turbos etc etc :)
I suspect the R33 owner if aware of the HPI review wont be looking at repalcing his T517Z's now with 2530s:)
yeah the 2530's do seem popular with a lot of twin turbo cars, like the 300ZX TT (which is 3.0lt) and the Soarer 2.5TT. You can't go wrong with the HKS setup, it's tried and true. But at the same time, don't discount the later released turbos from other brands. I too have heard the Apexi's spool up very quickly from a mate who had one on his R33 GTST, but i don't know what they are like in the topend.
I think that's a gross generalisation.
I haven't read HPI or Zoom for about a year now, and ph1 purchased the T517z turbos for his GTR when they were first released blind, without any feedback from other GTR owners, as he was one of the first to use them, and quite possibly the first in Australia to use them.
I thought they would be laggy due to the thrust bearing setup, but after going for a ride in ph1's car, my initial thoughts were unfounded.
This all happened before most people had even HEARD of Trust T517z turbos.
Off i go running for cover :Oops:
Yeh probably was a gross generalisation, and wasnt actually directed towards anyone in particular, but still i believe its true.
More people will be following ph1 down the Trust path because of the wrap they got in HPI.
Not to say thats a bad thing as feedback is great before purchasing something, but on the flip side its not fair that some parts are maligned or treated with "fear & trepidation" purely because a magazine hasnt gone to bat for them.
I do agree that many people rely on magazine articles to form their "own" opinions though...
It's quite amusing to talk to someone and hear them quote a Zoom article verbatim and pass it off as their own thoughts ;)
I could have sworn alot of people were bagging out plain bearing turbos only a couple of months ago.
That would have been Sydneykid and his "Trust turbos are truck turbos" comment :D
Sorry for comin so late, been away.
I can only vouch for my experience with Apexi AX53B60's. I've had em on my GTR for about 4 yrs, but only done about 12,000k's. I do remember they cost me a s**t load, I think about 7G's back then.
I reckon they're great, they aren't as quick responding as alot of you are hearing, but may have a fair bit to do with cam timing also. I've found them pretty awesome for street and track work, but a little lacking in response in a big heavy car for drifting( compared with the previous N1's). I get full boost by about 4800rpms, and it pulls hard to 9,000, but I pull the pin at 8. They're rated to 1.7bar, and I run mine at 1.3bar for around 300RWKW and 11.1 secs. I will be pushing them harder once I've run in my new forged bottom end.
A good mate also has them on an RB26, but in a GTS-t, and with bigger HKS272 cams, it's seen 365RWKW's on the same dyno @ 1.6bar.
On another note, they apparently have a "teflon" insert on the inlet side to limit wear on the compressor wheel, allowing a longer service life. I hope so! The full kit is very comprehensive, with all braided oil and water fittings, 'cause they're based on IHI components, so be careful if buying second hand. Also don't forget to port the exhaust manifolds!
I reckon they're perfect for a street/circuit/strip all-rounder. Cheers!
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
