  • Replies 64
  • 3 weeks later...
a pirates life for me
the new skyline on the oldschool back to the future car looks wierd, so here's a classic skyline on a classic car... meet the KPGC110 BTTF car
Jesus dark. Don't make me come down to slap the sh*t out of you.
Go rent 'Bullitt'. Now.
While you at it, get 'The Great Escape', 'The Getaway', 'The Towering Inferno' and of course 'Le Mans'.
The carchase in Bullitt - one of the most famous in history.
McQueen in his dark green 'Stang chasing a black Charger around San Francisco. He does all the driving. He is the ultimate mans man. He is rad. He is also dead - very sad.
if you got the dvd of bullit. play the part where the car scene is about to end (when the gas station blows up i think). If you play it in super slow motion you see some funny things.
1) When the gas station blows up the scene quickly changes to a black screen with a fire effect "very dodgy"
2) Now after the gas station if you look backround you see the car still driving (it was supposed to hit the gas station) but you still see it
3) When the makes that drift in the end the tyre just bends like 90's and as soon as it reaches the gutter it stops. That car would have definately tipped over after that scene.
oh is it, must be the NEO version, I use the non NEO version myself in my R32 when I went back in time and told your ancestors to screw that chicken, making you genetically speaking, a c0cksm0ker :mad:
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
