several things about temperature measurements:
-temperature probes are superior to infrared as surface temperatures may not be representative, especially excessive cooling on the surface relative to the deeper rubber and outer side of the tyre
-outside should be around 5-8 C lower than inside temperatures
obviously noticing excessive wear patterns etc are also a good indicator of correct camber setup for your track and suspension setup.
Yeah Mark agree with you there.
Sorry i meant that all tyres were consistent with each other and yep different temps from outside, middle to inside.
Im running 35-36 hot in the slicks and it actually takes quite a bit of time to get it right.
Im finding that you have to do 3 laps come back in and drop the pressures, then do another 3-4 laps and check them again, possibly let more air out.
Usually after this you can then leave them and they cool down and heat back up to about 35 without having to come in and check them every time.
We need to run our cars back to back!
would love to runa few laps with you guys. I am a beginner for sure so very interested to here everyones setup experiences.
I was running slightly lower psi, around 31 on tuesday, previously about 35 with the second hand tyres. will aim for around 33 next time I reckon. still managed a pb with the new tyres but will be looking closely at suspension tuning for next round.
also interested to hear what temps everyone is reaching on their slicks. I get big variations on inside/ouside of car on our clockwise tracks up here. might end up running a psi or more on the inner tyres to help get the temps up.
  • 3 weeks later...
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
