just ordered me some -9s
hope i'm disappointed
will post results when everything is in....
Any news yet? I'm also looking at -7 or -5's. Will be running JJR manifolds, xforce dumps, catco 3" cat, 4" catback, 100mm intake piping, 100mm intercooler, poncam a's, z32, sard 700's etc.. Stock bottom end for now but definately getting forged setup in the next 6 months.
Response is nice... But lag can be as well. Eg: I really love the T51R, the lag, the sound, the output. Different kit all together I know, but lag+severe power is a tick in my box. Given them details, what should I get?
With those details I would say -5s! You have all the supporting mods, you will be building a forged engine and you dont mind a bit of lag.
ok thought I might add my results... only just picked the car up yesterday
2860 - 9s from GCG
Stock motor... only mods are the turbos, cat back exhaust and PFC
270rwkw @ 15 psi... not a bad result I thought
standard AFMs were maxing out + injectors are almost at their limits
tuner said the shitty complaince cat is also holding back 15-20kw
now the goal is to get all the supporting mods, wind up the boost and go for 350rwkw
Im my opinion you would want to be careful pushing an unopened RB26 further than 300, if you have a great tune and your tuner is experienced it should be fine but anything over that mark wont last too long.
Keep it at 300 its a nice streetable number as 350kw you wont be using too often.
Its definitely laggier compared to standard turbos... will need some cam gears to help with lag
its punchy... top end is much harder than standard turbos
pretty sure actuators are aftermarket.... not exactly sure which ones tho... tuner said he did have to play around with the 'stock boost controller' to have an even 15psi line
umm full boost comes on around 4k i think... i havent really driven it much yet so not sure... will put up the dyno print out when i get home
im almost in the same boat as u man except i got -7's on my r33 gtr, got it tuned yesterday, managed to get 275kw at 1.2bar but it bleeds off to 1 bar by redline arghhh, injectors are almost hitting 100% aswell :)
im trying to find out the most cheapest way to solve the boost issue though, im running a profec b spec 2
6x injectors = about 900
1x fuel pressure reg = about 180
Because u only want a tiny bit more than the stock injectors will do. An increase in fuel pressure will get that easily.
I personally think cam gears are WAY overrated in the skyline community. U already have stock cams which are tiny, why further reduce top-end power from the already tiny cams? I understand tweaking cam timing on huge cams but i've never seen any evidence to show a gain in changing cam timing on stock cams. Fuel pressure reg and a set of Tomei Poncam type B cams cost about the same as injectors and camgears. I know which one would make bucketloads more all through the revs.
cam gears n cams are 2 different things, personally cam gears are great mod for the money, with my turbos I'm setting it for max response n powerband to start as early as possible
beerbaron has posted dyno of before n after cam gear mods with great gains, my car has similar results
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
