Aquired this beast the other week (wanted to get one for ages) and I'm pretty happy with it overall, except at the moment a renault clio sport will
stay on my ass at full throttle up to an 80km speed limit lol.
Plans are to make a street legal GTR that puts out 300-330AWKW and look the goods in my eyes.
It already had bigger brakes, ADR approved braided lines, 100mm frontmount intercooler, PFC, aftermarket exhaust that needs to be changed for something better, extreme HD clutch, optima battery, nismo dash. Everything else is stock.
First thing I did was remove the apexi pod filters and adapters, then source a stock airbox and snorkel assy and fit that along with a high flow panel filter.
This now makes it legal in NSW on that aspect.
Then got some neat white slimline plates to replace the crappy yellow ones. A front bracket will be made up soon.
All fluids will be replaced too.
Fitted some Rota 18x9.5 +12 offset wheels I had in the shed with 265 35 rubber. Keeping the stock wheels.
Here it is before I got it. Previous owner kept the GDZILLA plates.
Here's some pics of it now.
Have some new Garrett 2860-9's ready to fit to replace the stockers. Stockers are running at 1.2bar, no boost controller.
Alpine gear will go in soon too, using optical fibre link instead of RCA's, and some dyna mat.
Also may change the big end bearings for ACL race series as it's a little noisy for my liking before it gets oil pressure on start, and change the balancer for a Ross tuffbond....and the rest lol.
https://www.sau.com.au/forums/topic/323011-99-r34gtr-vspec-now-stroked/
Thanks Steve!
Ha ha, Chris, too late. I just started pulling it apart! I'll be dropping some stuff off to get ceramicoated though!
Owned it 2.5 weeks and this is what happens! I didn't want to chance the engine as it has a bit of bearing rumble before it gets oil pressure, so it's coming out. And the ceramic turbs are banned. Taking the engine out to do the work. Crank will get checked and balanced if all good.
Some more pics:
Garrett 2860-9's (GTSS) Radiator had some trash in front of it!
Piping is a bit oily from pcv pipes
Getting used to living under these things!
This was over two years ago, same shed!
you are just like a big kid that has to pull everything new appart to see whats inside :bunny: should go well once you get it all back together again.
Dont fret the clio thing, they have crazy short gears. stack a few more km/h on though and you should leave it behind.
Thanks Steve!
damnit! wanted to see how they went stock - oh well .... just dont try and polish the plenum on this car too lol
Well stock they are kinda like a R33GTS-T with a highflow turbo, and after 5000rpm it's flat. Plenty of torque around 3-4000rpm though.
So you weren't missing much!
Took the front pipe(s) off this arvo, not standard as it is big, equal length design too.
Now I'm going to source a service manual, as I haven't taken a pull type gearbox off before, only push types.
Thanks for the info!
Cheers, well better than a spun bearing lol.
Got the damn circlip off the clutch fork pin!. What a pain, and I ended up modifying screwdrivers to help get it off.
Looked different to the GT-T split pin? arrangement.
Unbolted the left hand drive shaft, and pushed the RHS drive shaft out of the diff.
Unbolted front prop shaft at the front diff.
Also unbolted the aircon and power steering pump from the engine to avoid disconnecting lines.
Wish I had a hoist!
Finally got the engine out today after a lot of cursing.
Then pulled the turbos and sump off. Broke a half inch breaker bar on the harmonic balancer bolt too, will exchange at supercheap (lifetime warranty!).
Inside of this engine was pretty black compared to my last engine I did, so it'll need a good clean.
Checked out the big end bearings and they did look a little tired. Shells had a bit of fretting on the backs and weren't a very tight fit in the bigends.
Will have to measure clearances another day. Main bearings looked better and thrust was good.
Dual mass flywheel, want to turf it!
V spec exhaust temp sensor on rear dump pipe
Dead breaker bar, big end bearing
Hmm yeah, would be nice but I have set a budget on this build as buying the car has made me broke again lol.
I will think about it though as more off boost response would be a side bonus with 2.6l and the 'heavy' 34.
Gonna sell some stuff in the shed so I might be able to budget it in!
I'll have a look at what is available piston wise :thumbsup:
Sump cleaned and Tomei baffle fitted, Cheers Andrew!
One of the engine mounts is half split through so replacement Nismo mounts it is.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
