Ha ha, nope mirror was facing a funny angle!!
Had a look in the daylight today and the only things that copped mirror glass was, driver window, b pillar, and rear spoiler blade.
Have to wash the car to see if any paint was damaged.
Also went back to the spot where it happened and picked up the plastic bits of the side mirror off the road.
  • 1 month later...
Fitted the pump, injectors and airflow meters. Then played with injector and airflow meter %'s to get it to run! Wide band 02 up the tail and made it run well enough to drive to the tuners. New set of spark plugs, 18PSI ran up 285AWKW.
The boost controller wouldn't hold boost properly above 18 PSI, and it was suggested that I get something better (EVC 6), as well as some newer cam gears as the old one's don't have timing marks. It now drives a lot better with the car pulling cleanly past 8000RPM where before you could feel it drop off after 6500-7000RPM. Makes me like the -9's even more! 22PSI is the next aim once boost controlling is sorted!
post-12712-0-24970800-1314364016_thumb.jpgpost-12712-0-37827400-1314364027_thumb.jpgpost-12712-0-94315900-1314364031_thumb.jpg
Just to get to the fuel pump, rear stiffener and brace need to be removed, also: rear seats, blanking plate, computer racks, plugs and connectors etc.
Injectors and AFM's are the easy part as usual!
I removed some dead weight, it added up to 9KG, but left the rear strut brace in of course.
post-12712-0-02509400-1314364041_thumb.jpgpost-12712-0-23562400-1314364044_thumb.jpgpost-12712-0-12394600-1314364049_thumb.jpg
I removed the carbon insert in the front bar to fit some mesh and refitted.
I suggest you run hks actuators if you want to run 20-22 pounds without the boost curve falling over.
My turbos spike to 1.5bar then drop down to 1.3bar by redline, i havent been able to get rid of that spike :(
Thanks Nick, I'm looking forward to more, but it's so good right now!
I'm already running the HKS adjustable actuators, as per previous posts.
Cheers Chris, They are the same size physically, but the nismo offers more flow. I just wanted a fresh bolt in solution. The 044 will outdo it at higher boost, but not for my aims.
Ha ha it's staying on the car Luke!
hey mate cars coming along beautifuly !
what boost control problems did you have Sean? those wastegate actuators should be holding boost much more steady as the boost controller isnt working as hard. did it spike to 20 or so psi then drop to 18psi by redline?
thanks
I'm thinking it is more the wastegate actuators fault, they are holding 11.5psi with controller off, so I will need to put in more preload on the actuators.
Controller is struggling to hold higher boost, 18psi+ for example. Graphs I got today tell the story.
AWKW
Once I sort out actuators, it'll will be ready for 22psi :D
Wow that boost curve looks EXACTLY like mine.. good thing im getting rid of my twins next week! :action-smiley-069:
Great power considering max power is being made at only 1.2bar :laugh: almost exactly what i made with -7s.
Edit: does anyone think its a possibility that the stock bovs are opening slightly when on full boost hence the boost falling over? I wonder if stronger BOVS will make any difference.
Edited by snozzle
  • 1 month later...
Got some new bits to fit, nismo stuff!!!
So I fitted the Nismo MFD upgrade boards and new map sensor. Did the calibration and it all works.
G sensor, lap timer, oil pressure, 2 bar boost gauge and more scale on the other readings.
Also got the oil air seperator tank kit, and I'll probably fit that soon.
You know it Bob :thumbsup: thanks again.
Thanks RBish, the nismo mafs I chose because, I have played with map sensor based stuff on the 32 I used to have. Takes longer to get right and altitude stuff it around too.
I got them for $700 or so new but they usually go for around $900. Good to have fresh bolt in stuff.
really looking forward to this :D
when's it going in next?? and who's doing the tune??
i probably should get heavy duty actuators before getting mined sorted too
Patience grasshopper!
Here's some pics of the oil/air separator tank fitted. It took 2 hours to fit, top hoses were easy, then jack the front up to get to the rear turbo oil drain fitting and replace it with the new 3 way fitting. Only had to remove the bottom chassis brace to get in there, and use some uni drives to get to the bolts etc.
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
