  • Replies 44
im a bit confused,
my car has 2 BOV's it has the stock one which goes back into the intake and i have a HKS SEQ as well? i have wound the boost up to 11.5psi, should i be removing the stock bov?
hey Ash
I have the same prob as u...they left my stockie on wen the put the HKS one on..
if u find out wat to do can u tell me plz :)
thanx man
SXCSKY i have the exact same setup as you! :) same place and all,
i don't know if u loose power, i think thats only if it leaks, but how do you find out?
Hey Ash...i dunno how to find out...im takin it to UAS 2day and see wat they say
Tell us if u find somethin out
cheers ;)
howdy... my skyline aint got a BOV.. but has a POD... anyways... i want a BOV on the beast and by what i have read... being a girl and all... a BOV basically could lengthen the life of ur turbo... any one object? or has reasons y i shouldn't invest in one??
u dont want Atmo bov and plumbback. coz the plumbback is known to leak over certain boost levels which will lose u boost. thats one of the reasons u upgrade to HKS or watever. as far as pressure goes, it wont make much difference since its just doubling the release of air which is good. some going back in will act like them hybrid bovs too stopping it stalling or watever coz it stil lgets air back to the AFM. but it will make the HKS quieter too probably coz not as much air coming out of it.
id remove the original i reckon. just block up the places where it goes in i.e. put blockers up any pipes that are left from it's removal. easy.
no need for 2! or yeh u could also just jam it shut somehow but easier to take it off and fill the holes with something and clamp it up nice n tight. :)
R33NismoGirl - Your car has a blow off valve standard. Has it been removed?
Ash - there is nothing really wrong with having 2 BOVs. (GTRs have 2). The factory one would have been left in place to help with maintaining the factory idle characteristics. The 2 valves will flow much better than 1 and will therefore work more effectively.
Cameron & Ash - There is a thread on these forums about modifying the stock BOV that you may find interesting.
Thats cause gtr's have 2 turbos :D hehe
yer i've herd the bov mod works good.... ?
Well I am going to disagree with a few people here then...
recently I installed a pod, K&N tapered with chrome end...have had it for about as long as they have made this model (used to be on one of my dads many drag engines) anyway it sounds awesome, good suction noise and scares the bejesus out of the od commo driver...
You CAN hear the standard bov, and it is working fine, however I have replaced the standard BOV with a GFB stealth and all I can say is giddy up...
At full plumb back it seems to hold and come on boost quicker, I am aiming to dyno to prove my point unless someone beats me to it, has already been proven on a s15...
add to this at FULL atmo the car STILL idles like factory no backfiring, no hiccups nothing, its all a matter of a bit of spring adjustment. This is only factory boost (9psi??) and I am very happy...espcially after I replaced the BOV gasket with a new one as the old one created a high pitched squel which was in fact a boost leak....
hey guys
Ok nowim confused 1 dude says its ok to have a stockie BOV with ya BLITZ BOV ...and another says seal it....and another says just switch the vacuum hose over to the BLITZ BOV .....ok guys so wat should i do then .....????? plz someone tell me way to many opinions on this subject :headspin: ....oh yeh can someone help me with the reason y i get a small backfire wen after the BOV goes off????
thanx guys :D
as far as i can see i dont have one... but i have been tol i do but it dont make noise?! i dunno i new to skylines only had it for 10 months & still learning more everyday... if someone caould give me some more info on where to find to standard BOV that would help other than that i am lost... thanx for the tips guys... i am thinking NOT 2 worry about getting one. i just got my beast back after a cracked head & head gasket lol shit happens... damn trucks!
If you have a stock airbox you won't hear the stock BOV...
i havn't got a pic to post but if you look at the pipe where the air inlet connnects to the intake manifold (near the firewall)... you'll see the stock bov with a black rubber hose coming off it.... sorry, i'm not very good at explaining but if someone can post a pic that'll show you where it is....
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
