  • Replies 44
im a bit confused,
my car has 2 BOV's it has the stock one which goes back into the intake and i have a HKS SEQ as well? i have wound the boost up to 11.5psi, should i be removing the stock bov?
hey Ash
I have the same prob as u...they left my stockie on wen the put the HKS one on..
if u find out wat to do can u tell me plz :)
thanx man
SXCSKY i have the exact same setup as you! :) same place and all,
i don't know if u loose power, i think thats only if it leaks, but how do you find out?
Hey Ash...i dunno how to find out...im takin it to UAS 2day and see wat they say
Tell us if u find somethin out
cheers ;)
howdy... my skyline aint got a BOV.. but has a POD... anyways... i want a BOV on the beast and by what i have read... being a girl and all... a BOV basically could lengthen the life of ur turbo... any one object? or has reasons y i shouldn't invest in one??
u dont want Atmo bov and plumbback. coz the plumbback is known to leak over certain boost levels which will lose u boost. thats one of the reasons u upgrade to HKS or watever. as far as pressure goes, it wont make much difference since its just doubling the release of air which is good. some going back in will act like them hybrid bovs too stopping it stalling or watever coz it stil lgets air back to the AFM. but it will make the HKS quieter too probably coz not as much air coming out of it.
id remove the original i reckon. just block up the places where it goes in i.e. put blockers up any pipes that are left from it's removal. easy.
no need for 2! or yeh u could also just jam it shut somehow but easier to take it off and fill the holes with something and clamp it up nice n tight. :)
R33NismoGirl - Your car has a blow off valve standard. Has it been removed?
Ash - there is nothing really wrong with having 2 BOVs. (GTRs have 2). The factory one would have been left in place to help with maintaining the factory idle characteristics. The 2 valves will flow much better than 1 and will therefore work more effectively.
Cameron & Ash - There is a thread on these forums about modifying the stock BOV that you may find interesting.
Thats cause gtr's have 2 turbos :D hehe
yer i've herd the bov mod works good.... ?
Well I am going to disagree with a few people here then...
recently I installed a pod, K&N tapered with chrome end...have had it for about as long as they have made this model (used to be on one of my dads many drag engines) anyway it sounds awesome, good suction noise and scares the bejesus out of the od commo driver...
You CAN hear the standard bov, and it is working fine, however I have replaced the standard BOV with a GFB stealth and all I can say is giddy up...
At full plumb back it seems to hold and come on boost quicker, I am aiming to dyno to prove my point unless someone beats me to it, has already been proven on a s15...
add to this at FULL atmo the car STILL idles like factory no backfiring, no hiccups nothing, its all a matter of a bit of spring adjustment. This is only factory boost (9psi??) and I am very happy...espcially after I replaced the BOV gasket with a new one as the old one created a high pitched squel which was in fact a boost leak....
hey guys
Ok nowim confused 1 dude says its ok to have a stockie BOV with ya BLITZ BOV ...and another says seal it....and another says just switch the vacuum hose over to the BLITZ BOV .....ok guys so wat should i do then .....????? plz someone tell me way to many opinions on this subject :headspin: ....oh yeh can someone help me with the reason y i get a small backfire wen after the BOV goes off????
thanx guys :D
as far as i can see i dont have one... but i have been tol i do but it dont make noise?! i dunno i new to skylines only had it for 10 months & still learning more everyday... if someone caould give me some more info on where to find to standard BOV that would help other than that i am lost... thanx for the tips guys... i am thinking NOT 2 worry about getting one. i just got my beast back after a cracked head & head gasket lol shit happens... damn trucks!
If you have a stock airbox you won't hear the stock BOV...
i havn't got a pic to post but if you look at the pipe where the air inlet connnects to the intake manifold (near the firewall)... you'll see the stock bov with a black rubber hose coming off it.... sorry, i'm not very good at explaining but if someone can post a pic that'll show you where it is....
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
