Hi Has anyone weighed there R34 GTT Coupe,The specs say 1410 kilo's.How close is this to reality.
Hi Steve,
good question, I'd be keen on getting a definitive answer as well (for an R34 GTT sedan).
Different sources have slightly different figures:
http://en.wikipedia.org/wiki/Nissan_Skyline#R34
- 1410 kg (4-door sedan / 2-door coupe)
http://www.japanesesportcars.com/skyline/s...4_ggt_turbo.php
- 1490 kg (sedan) / 1340 kg (coupe)
http://nissanskyline.6te.net/GTT_spec.htm
- 1410 kg (4 door sedan or 2 door coupe)
http://www.performanceforums.com/forums/sh...tcount839233944
- 2.5 25GT Turbo coupe 1430kg (4AT), 1410kg (5MT)
- 2.5 25GT Turbo sedan 1450kg (4AT), 1430kg (5MT)
The Performance Forums numbers seem pretty good, i.e.
- base weight 1410kg for R34 GTT coupe manual
- add 20kg for automatic transmission
- add 20kg for sedan
Can anyone confirm these please?
https://www.sau.com.au/forums/topic/323320-r34-gt-t-weight/#findComment-5271922
Always remember when reading weights off of the internet is that you don't know whether it includes all fluids, spare wheel and accessories and what factory options it may have (sunroof, dual airbags, ABS, etc.) as all the running fluids (engine oil, gearbox oil, diff oil, brake fluid, power steering fluid, coolant etc) in the vehicle can add 20-30kg. Than a full tank of fuel can add 50-70kg, suddenly you have a car that weighs 100kg more than what is written on the internet just in fluids.
I weighed my car (R33 GTST SII) on a weigh bridge with me in the car and half a tank of fuel and it was 1500kg. So take away my weight and the half a tank of fuel and your looking at around 1400kg with all running fluids (minus fuel) for my R33. My car has ABS, dual airbags and an A-LSD so has a lot of extra weight compared to a R33 without these things. Has a few things lighter than factory items and a few things removed, but it would probably be offseted from all the modifications added to it.
Vehicle weights are hard to get accurate unless weighing the particular car as some mods save weight (carbon panels, lighter wheels, lighter exhaust) and a lot of others add weight (coilovers, speakers, intercoolers, bodykits etc). So always use what you read as a guide and think about all the variables.
I would love a database on this website with a lot of items weighed accurately so people can add/subtract things to get a better idea of weights.
Edited by PM-R33
https://www.sau.com.au/forums/topic/323320-r34-gt-t-weight/#findComment-5275839
but you will still get the problem of different scales having slightly different calibrations and margins of error.
https://www.sau.com.au/forums/topic/323320-r34-gt-t-weight/#findComment-5278214
  • 1 month later...
This is the weight as taken from the original Japanese owners manual converted to English. :(
2WD (Rear wheel Drive)
Vehicle Weight: RB25DET 1410kg RB25DE 1340kg RB20DE 1330kg
4WD
RB25DET 1450kg
GT-R 1540kg Curb Weight
GT-R V SPEC 1560kg Curb Weight
Hope that helps :D
https://www.sau.com.au/forums/topic/323320-r34-gt-t-weight/#findComment-5348789
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
