Cube wheel options
60 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 114
Nah your reference was perfectly clear Christian - Dave is just a bit slow :blush:
I also could never figure out why Dom had the "TeamSR" sticker on his front windscreen - doesn't he know he drives a rotary - not a tractor!
It was Team "Spit Roast" or something like that.
Gayer than aidz.
Nah your reference was perfectly clear Christian - Dave is just a bit slow :laugh:
yeah... i am, but mostly i just wanted an excuse to use that picture. :)
Are those chromed R32 GTR Rims? They look pretty nice there..
-D
nope, 32R rims dont have dish
32 rims are also 5 stud last i checked.
cubes are not.
Edited by scandyflick
Kristian. Time to display some testicular fortitude.
Step 1. pick up a cheap set of OZ Racing Futura wheels on YAJ.
Step 2. bust em apart
Step 3. order the right width barrels out of germany/uk to attain flushness.
Step 4. powdercoat that shit to match the cube
Step 5. dump it on its arse (airbags recommended) use the Nissan Micra kit out of the UK or go homebrew locally
Step 6. Assume title of king baller... and profit.
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
