  • Replies 85
Ok, So since the helmet that I use (Thanks Paul) still has Green Wang pump racing on it. I think the team will have to be re-united.. Hopefully Scotty won't burn out the clutch this time.. :laugh:))))))
Team Green Wang Pump Racing FTW...
as maka reported, the dust has been blown off the green wang pump and i just tested it out... shes a beut!
looking at the total lack of trash talking happening here, i can see there is a total lack of team honor and that can only spell TGWP dominance.
Mike... youll need to drop more than 20kg of that super structure to make any difference... i think i saw the making of mike on the discovery channel "engineering marvels"
Bard... i know you can drive... but... with poor team selection, one can only challenge your decision making skills so clearly your mind wont be there on race day
Paul... now your a dad you will likely have a baby seat strapped to the back of your kart and a "baby on board" sticker so i expect to pass you on a regular basis as you chug around the track at "school zone speed" taking notes of hoon drivers to complain about
Tom... just crash
Scott McKickass
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
