Missfire Boost@4500-5500 RPM - The Answer! (for me at least!)
Quick question ppl..
Can someone describe what this feels like when occuring..
Went for a drive on sat in an R33 - in second car would hit about 4,000 - 4,500 than for a split second it would lag/pause/slow/stop/cruise however you want to put it for about 500rpm than it would kick in again and race to redline..
is this the same issue.. talked to the guy and he said "most likely fix it by adjusting the timing".. wasn't sure about that, seems to be the same issue as this..
didn't hear any missing, didn't feel like it.. just kinda paused for a second than came back on the power..
I'm having some trouble. Put new spark plugs in gapped to 0.8mm. I thought the coils looked ok. Couldn't see a hairline crank on the front, though maybe I missed it. But most of the coils had stange bits on the side where it looked like they had seen lots of heat.
Just lately I get a misfire, well more like a boost cut but it happens at just above 3000rpm up a hill in 4th gear at 0.65bar (about 9.5psi).. I thought maybe it is the ECU sensing too much airflow and going rich and retard. But I thought this was at more like 12-14psi...
Can somebody have a look at the pics below..not the best but gives an idea of the what is going on on the side. I heard somebody in the thread saying the heat on the side may be from arcing?
I did a decent job of taping my coils up, worked fine for about 1 week
then back to the same old crap of laggin round 4500-5000rpm
have since poured some octane boost into a 1/4 tank of petrol and it now revs straight to 7500rpm
definately think the coils can be a bit of an issue but is more likely due to poor octane ratings of aussie petrol
just took my car for a thrash with the boost wound up to about 1 bar and it is still loving it
why oh why dont they sell some decent petrol in australia
hey, I had the same problem for 3 weeks. it started off, missing and shitting its self around 4 to 6 tho.
And as the weeks went by it got worse, anything over 2 grand made her crap on!
i pulled out my coil packs and a few of them were marked like were you can see spark has been jumping out of the side of the coil..
i checked the plugs, they were alittle but crap from fule not being burnt.. but i cleaned them and wacked them back in.. and slipped in some new split fire coil packs in..
took her out for a belt and it works fine now, up around 6 and a half grand she splatted once but i have noticed a big jump in get up and go!!
Oh and idling is HEAPS better, it used to surge a little, now gone..
The only other thing im going to do next is take the AF sensor out and spray some contact cleaner on the sensor part, Im sure that will help a little bit too..
the last time i cleaned out my air filter, i think i used too much oil in the filter, and if it gets on the sensor it will cause it to faul up !
So i think a few of my coils are still fine, ill have a good look at them and test the ones that are good, and if anyone wants to buy some off me they can..
[email protected]
Have any of you guys had you computer's remapped to run on 98 octane petrol
would like to hear any experiences people have had after getting their ECU reprogrammed
Coils seem to be part of this problem of missfiring, but im sure the low octane ratings of aussie petrol are having a significant affect on performance
Most of this cars would be running on petrol with octane ratings of 100 or more in japan
From what I understand jap fuel is 100.
2 points doesn't make a big difference.
The majority of people do not have issues with missfiring.
It is definitely not the fuel, rather the coils.
My PowerFC's base map ran aggressive ign. timing at WOT.
It only made the thing ping its head off, no miss-fires.
However, there is such a thing has a lean missfire. Run the car lean, it will detonate then get to the point where there isn't enough fuel and will begin to missfire.
Took my coils put today and 3 were split on the greay part surrounding the metal thing. Very technical eh? Taped them up but in thr process I noticed a shitload of green calcium build up and general crud up inside.
I took a Dremel (small high speed drill thingy) and lightly ground the inside of each coil pack until it was shiny again. I already had new springs inside and I screwed a tiny allen bolt up the guts of each spring to replicate the factory set up.
In all I had about 3 teaspoons of carbon/calcium/crud I removed from all the coilpacks.
Result is fixed mis firing, stronger performance, better idle. :rofl: Worth the effort if you have the tools.
Result is fixed mis firing, stronger performance, better idle. ;) Worth the effort if you have the tools.
http://www.skylinesaustralia.com/forums/sh...?t=51046&page=2 post #57
No need for Dremel tool.
Just spray some WD-40 or CRC-50 on them and it washes off instantly!
Then just rub inside with a bit of steel wool for a few seconds and they are right to go.
well, i can say after puting in the new coil packs. It went alot better, but it has come back!!
noooooo, but not as bad! it feels like when ya in 4th and you power up alittle it hits this ,,, like flat spot, but its a miss spot! thats when it starts to piss me off..
I took the AF meter off, and sprayed a heap of contact cleaner(the one that desnt leave a resadue) and let it dry... but still doing it!!
ill change the apark plugs on the week end, and if that desnt fix it... well im going to sell it and get a holden
nah mine did not come out with just degreaser or anything. Its easier with a high speed buffer anyway :thumbsup: Mine were well and truly stuffed...
To do one of them with steel wool wrapped around the end of a drill bit (I know it's no dremel tool) took me a few minutes, and there was still some left...
To do all 6 with WD40 took 30 seconds. I then used the steel wool to clean any residue. Spraying degreaser will do nothing, you need to use WD40 or CRC50.
WD40 is much easier.
reagardless, the car runs fine now and the packs are nice and shiny. How ever its done doesn't really matter. I tried with all sorts of cleaners last time, they did sfa. I think after 15 years it was beyond it.
The dremel took 5 seconds on each coil to bring them up like new so I still stand by the method if you have access to one.
whatever works for you :rofl:
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
