Hey guys,
Your all probably going to reply with "you idiot" or "your the reason skylines are in such bad condition" but please bare with me, im just new to cars and my whole family is car illiterate so I had nowhere to learn from.
Ive had my skyline for perhaps a month now and everything was fine when i first got it, but now i checked oil and water and noticed that my coolant is pretty much empty, I cant see any liquid in it and I don't even remember what colour the coolant was.
I have no intent on driving it until I get this refilled properly, but I have no idea what coolant to go with, I barely know anything about coolant other than it comes in varying colours which are generally used as a guideline but I don't even have that info.
Any help?
https://www.sau.com.au/forums/topic/323788-coolant/
I had a look in my radiator and found it had a green coolant in it, upon recommendation from a few close apprentice mechanic friends and my mechanic, I was told that Nulon green was the right one to go with, anybody got any opinions?
https://www.sau.com.au/forums/topic/323788-coolant/#findComment-5277464
When my mechanic did my new spark plugs he said he found a crack in a hose that he fixed up, my best guess is that where it all went... but if it continue to leak after i replace the coolant then i'll start worrying and search for another explanation.
https://www.sau.com.au/forums/topic/323788-coolant/#findComment-5277605
And dont forget to bleed the system - there will be a bolt near the top of the motor, drivers side near the front. Look for a gold sticker. Take the bolt out which will let the air escape then close it when the coolant flows. Or something like that....
https://www.sau.com.au/forums/topic/323788-coolant/#findComment-5282026
^ +1.
However bleeding the system that way takes a while, and you are more prone to burning urself with hot water.
I usually reverse into the driveway, so that my front is higher then my rear(radiator top being hte highest point in the engine bay). I simply start the car, and let it idle for about 30-40 mins. Amazing how much air is trapped in there.
https://www.sau.com.au/forums/topic/323788-coolant/#findComment-5282753
^ +1.
++1
when i flushed my coolant i had so many close calls haha
https://www.sau.com.au/forums/topic/323788-coolant/#findComment-5284197
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
