the box in my car is an r33 turbo box but from one to two its got a nice notch to it and if i dont be really careful itll crunch.
the rest of the gears are perfect in the way they feel.
is it possible to just rebuild/replace the old syncro's in that gear?
im not in a place thats easy to ask.
they keep telling me they just send the box away and get another back. but thats 1300ish and id prefer not to spend that in my current situation....
is it possible to just do the gear that needs doing?
thanks
https://www.sau.com.au/forums/topic/323834-box-rebuild/
AFAIK you can just replace the 1 synchro that is crunching....but if one is gone the rest almost certainly are going or gone too. And there are bearings and seals that should be replaced too.
BTW 1300 sounds cheap to replace all the synchros and bearings. Or is that the cost to get another second handbox? If so I'd probably give it a miss, almost every box will have these issues to some extent by now.
You can just do what most people do - run the Redline Lightweight shockproof gear oil and slow down your gear changes a little....it won't fix anything but it might hide the problem for a few years.
https://www.sau.com.au/forums/topic/323834-box-rebuild/#findComment-5278050
1300 is a reconditioned box
a second hand bax goes from about 300 to 600 here.
if shockproof is that good i might give it a go. althought i have heard some stories that some times it makes it worse.
https://www.sau.com.au/forums/topic/323834-box-rebuild/#findComment-5278108
i have the same gearbox and i personally rebuilt it a few months ago. trust me - if your going to replace one synchro you should replace them all, as well as all bearings in it. never trust a 2nd hand gearbox, you just have no way of knowing what condition its in. sure it could run fine now, but how long will that last? these gearboxes are all getting old now and i would put money on the fact that every one of them has seen a good bit of abuse over the years so i definately wouldnt waste my time with a 2nd hand box, you really are opening a can of worms if you do.
to get at the 1st/2nd gear synchros the whole box basically needs to be stripped which is a big job, and since you dont tend to strip your gearbox very often it would be a pretty dumb idea not to do the rest of them while your in there, as they are more than likely not far away from doing the same thing. be warned though, syncro's are expensive. they are likely to cost just as much or perhaps more than the labour charge to do it. over here in nz they were $1160 with trade discount. dont be suprised if you find them around $1000AUD.
see the reference picture attached this is of my actual gearbox during the rebuild. it points out where the synchros are in case your unfamiliar with what your up against. they are the bronze coloured rings highlighted by the arrows. if you dont have any experience with gearboxes do NOT attempt it yourself. even for me this thing was a bit of a nightmare
https://www.sau.com.au/forums/topic/323834-box-rebuild/#findComment-5282300
What the hell? where is "here"???
My 25t box cost me $1500 2nd hand!!
https://www.sau.com.au/forums/topic/323834-box-rebuild/#findComment-5286157
thanks for the info.
makes a bit more sense now.
im in japan.
there between 300 and 600 depending where you buy it and how much risk you take on it being good or bad.
to have a box changed at a shop here is 200-300 plus oil. if i was at home in aus id do it myself where here i cant which is a bugger.
https://www.sau.com.au/forums/topic/323834-box-rebuild/#findComment-5286313
im in japan.
Wow.
When I went to upgrade to a 25t box, it was $1500 for an unknown 2nd hand with no guarantees and that seems to be the going price everywhere over here.. occaisionally you'll see one for $1200 from a private seller.
It's quite annoying and disgusting but hey, what can you do? For $600 for the least risk I'd break 3 and replace until I felt I needed to rebuild one.
GTR boxes go for 600ish but a fair effort to turn it into rwd.
Good luck :/
https://www.sau.com.au/forums/topic/323834-box-rebuild/#findComment-5288064
i bought an unknown condition 25t box over here in WA for $300. pulled it apart it had signs of water being inside but other than that im sticking a kit an sychros through it which cost twice the price of the box
https://www.sau.com.au/forums/topic/323834-box-rebuild/#findComment-5290016
Are you doing it yourself?
https://www.sau.com.au/forums/topic/323834-box-rebuild/#findComment-5292067
Can you lap in old syncro's in skyline box's. When I was in the Automotive industry. Lasted 4 weeks. One of the head mechanics said you can lap in some of the holden syncro's to make them work again. I guess they become glazed or the scores on them wear off?
Wondering if it works or if people have heard of it or tried?
https://www.sau.com.au/forums/topic/323834-box-rebuild/#findComment-5298629
bubba, yeah i can do more for ya. am located in bunbury tho.
you can use fine valve lapping paste to lap the synchro back into the cone but if its to worn its just a waste of time and you'd be better off with new synchros
https://www.sau.com.au/forums/topic/323834-box-rebuild/#findComment-5300211
Cool, bunnos not really that far away ;)
We'll see how long the current box lasts when the new engine/turbo setup is in.. the box has crunched 2nd a bit ever since I got it :( I got around that by just starting in 2nd instead of trying to hit 2nd :)
https://www.sau.com.au/forums/topic/323834-box-rebuild/#findComment-5310761
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
