I have an R34 GTT, current modifications i have on my car are intercooler, exhaust, Bosh 040 fuel pump, pod filter (boxed) & Boost controller.
I'm booked in for a tune on friday, i was hoping to get about 250rwkw from my car.
Any recommendations on what other mods i need to achieve my goal.
Thanks in advance.
https://www.sau.com.au/forums/topic/323983-urgent-help/
Thanks in advance.
A bigger turbo and an ecu
https://www.sau.com.au/forums/topic/323983-urgent-help/#findComment-5279971
Should've got all the parts before the tune. Generally you need:
550cc injectors
Z32 AFM
Boost controller
3inch metal inake pipe with good pod filter
3inch exhaust with Honey con cat
High flowed turbo
Strong clutch
fule pump
Nistune or better ECU
Feed it with BP ulitmate.
https://www.sau.com.au/forums/topic/323983-urgent-help/#findComment-5279975
the "tune" you have done on friday is going to consist of the workshop driving the car onto the dyno, doing a run or 2, possibly playing around with the boost level, doing another dyno run and then driving it off again. the stock ecu can't be tuned.
and as has been said above, you are going to fall short of your goal of 250kw by about 50kw.
https://www.sau.com.au/forums/topic/323983-urgent-help/#findComment-5280341
...or more. With a standard ECU you'll probably hit rich and retard (as i did) eventually which makes the car a pig. I managed 185rwkw with exhaust, pod and 13psi.
With an aftermarket ECU and Z32 afm (or a better ECU with 3bar map sensor ie Haltech) you might be able to make 210+ on the standard turbo, although don't expect it to last all that long at that power level...
https://www.sau.com.au/forums/topic/323983-urgent-help/#findComment-5280687
You'll need a credit card...............with approx. a $5000 limit.
Then you can buy all the necessary hardware!!!
At least...! I just dropped $12k on my R34 to make 273kw, although that was with an expensive ECU and other parts and it has plenty more left in it for E85...
https://www.sau.com.au/forums/topic/323983-urgent-help/#findComment-5280710
I reckon you would pull around 200rwkw ... you need the turbo +and both aftermarket ECU and Injectors
I'm voting 180-190(ish) tops.
Fuel pump and intercooler will make exactly zero difference to power and as i mentioned my 34 made 185rwkw with some boost, pod and exhaust.
Of course Dynos do all read different - 200 on one is 180 on another...
https://www.sau.com.au/forums/topic/323983-urgent-help/#findComment-5280787
not quiet true. fuel pump won't do squat for power, but as you start doing other mods then you need a better fuel pump to be able to flow enough fuel to stop it from leaning out.
as for the intercooler, they can make you get higher power than the stock one. the reason being that if you give the car a bit of a fang on the way to the dyno then the stock side mount cooler will already be suffering from heatsoak (therefor higher intake temps and less power) before it even goes on the dyno. a bigger intercooler will stay cooler for longer and therefor give you higher power on the dyno (as well as on the road). it doesn't take long for the stock cooler to heat up after you have given it a boot a few times, while in the colder days we are having at the moment a fmic will stay cool for much much longer.
https://www.sau.com.au/forums/topic/323983-urgent-help/#findComment-5280956
The fuel pump will only help once you reach the limit of the standard system (as you say) which won't be happening here.
The cooler - well it may help in the situation you described, true - but usually i'd assume the car would be sitting around, run a couple power runs and that's it, with a fan blowing into the engine bay. This is not a proper 'tune'. It can stop power loss through heatsoak / high inlet temps yes, but it's not going to give you more power per se.
Essentially what I meant was your not going to get an extra XXkw with those two mods... :D
https://www.sau.com.au/forums/topic/323983-urgent-help/#findComment-5281075
Essentially what I meant was your not going to get an extra XXkw with those two mods... :domokun:
and i pretty much agree
https://www.sau.com.au/forums/topic/323983-urgent-help/#findComment-5281229
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
