Hey every one
Just wanted a bit of input.. im thinking of buying a cusco 2 way diff for my car, i use my car as a daily to go to uni but at the same time do a fair bit of AHG/RAC track days.. Im also looking into attending some Barbagallo events from next year.
Ive read on the forums a bit and found out that the Nismo 2way is the smoothest and quietest, followed by the cusco, which is followed then by the Kaaz 2 way..
I wanted to know if any one on here uses a 2way in a daily driven car, also what they think of the Cusco 2ways compared to all the other diffs out there? and finally am i going to have a lot of issues/problems by installing a diff like this on an every day car?
cheers guys, Ni
https://www.sau.com.au/forums/topic/324356-2-way-diff/
I have one.
I use my car as a daily. You get a few odd looks and your neighbours think your ripping a skid when your turning around etc, but other than that its fine.
Cant help in regards to branding as im not 100% what mine is. (came out of a car imported from japan that hadnt been to compliance yet)
https://www.sau.com.au/forums/topic/324356-2-way-diff/#findComment-5286382
I have one.
hey man!
how have you been?
Thanks for the info, is it a pain when it comes to parking in a shopping centre or something?
Cheers, ni
https://www.sau.com.au/forums/topic/324356-2-way-diff/#findComment-5286624
get a 1 or 1.5 way, there is plenty of info on the net about how they work. 2 way = drift diff,
drift diff not the best for the street.
Hey dude
Yep i read up a few docs the reason i posted it was because some people say the 2way isn’t as bad as people think they are and that if you know how to drive with that diff correctly its not too much of an issue
cheers
https://www.sau.com.au/forums/topic/324356-2-way-diff/#findComment-5286630
not really. clutch in and your fine.
skips a bit if your driving into the spot. if you really want you can give my 32 a drive around to see what its like. PM me if you want.
Hey Greg
Oh awesome thanks alot for the help. All good bro i know how much your skyline means to you, i wouldnt want to take it for a drive and then loose control or anything :P
Cheers, ni
https://www.sau.com.au/forums/topic/324356-2-way-diff/#findComment-5286637
ive driven both a kaaz 1.5 (my car) and also the 2 way and found the 1.5 gives a verry similar performance on track with more comfort on the road
but my sugestion is drive as many as you can a make a decision based on that cause YOU will be doing the driving
oh and your welcome to take cherrired for a thrash once i replace the shifter
https://www.sau.com.au/forums/topic/324356-2-way-diff/#findComment-5286694
I can vouch for Nismo 2 way. Is quiet, but it's definately no daily driver.
Hard locks up on uneven ground or sudden turning, will lock up in any case (a bit sifter, but occasionally locks up hard) on accel, decel, any kind of turning, and parking.
Not too bad on the streets, reversing up my driveway is still a little tricky.
Also stupidly difficult to control at low speeds in the wet if you're actually trying to keep some traction.
https://www.sau.com.au/forums/topic/324356-2-way-diff/#findComment-5286758
Hey man, i would like to buy a 1.5 way however ive found a 2way cusco diff that is going for a good price.. that’s one reason for me asking
and at the same time my standard diff is on its way out.. it hums really loud and clunks here and there :) .
Thanks for offering to let me drive your car everyone on sky aus is great.. got to love this forum and the people in it :miner:, however i'l try it out on mine and see how it goes as I would be over concerned if I drove another person's skyline .
Cheers
Hmmm is it really hard to get a grasp of i don’t mind the traction loss here and there, however will it break traction even if i just make a simple right turn? also if i clutch in around the corner would this de activate the diff or as its a 2 way would it always be locking no matter what?
thanks, ni
Edited by niran
https://www.sau.com.au/forums/topic/324356-2-way-diff/#findComment-5286884
you will have zero issue with a nismo 2way lsd on the street if you run it in correctly and change the oil (nismo state every 3,000km)
Comparing my nismo 2way to my mates kaaz 2way, my nismo was alot more street friendly and was alot more quicker.
I have a NISMO GT LSD for sale in 2weeks done less than 2,000km (Running Motul completition oil 17W140, the oil nismo recommends), comes in housing with side shafts (everything less than 2000km old bears, shafts etc) $1250 come out of r33 gts-t so suits 5 bolt flange r200 diffs.
also got 2L of nismo completition dif oil 75W140 aka nismo motul if you need it.
Also my dad has driven my car more than me in the last 2,000km and he had no issue with losing traction or anything else when driving the car. same goes for me.
And 2way is not for drift only....
Edited by Kaido_RR
https://www.sau.com.au/forums/topic/324356-2-way-diff/#findComment-5286907
Hey man
I will stick to the Cusco 2way, however how much do you want for the 2L of nismo/motul completition dif oil 75W140 ? and would this be suited for a cusco 2 way.. or is it the wrong oil for this type of diff.. cheers
ni
https://www.sau.com.au/forums/topic/324356-2-way-diff/#findComment-5286916
Hey dude
cheers
thanks champ, i better learn how to drive my car, its only had the 2 way mech diff installed for 5yrs.
I'm speaking from experience, i would get a 1.5 way if i was to do it again.
https://www.sau.com.au/forums/topic/324356-2-way-diff/#findComment-5287369
1.5 is best for street , both my cars run them
LOL Why would you need a 1.5 to reverse back to letterbox and go forward again ? :thumbsup:
https://www.sau.com.au/forums/topic/324356-2-way-diff/#findComment-5287394
sorry if i offended you didn't mean it in that way, i'll try out the 2way diff myself and see how it goes from there
thanks, ni
Edited by niran
https://www.sau.com.au/forums/topic/324356-2-way-diff/#findComment-5287596
2way diff in my car
like was said earlier can be abit of a pain at slow speeds in the wet, especially the first rains after dry spell. concrete driveways and such are noisy when turning ie service stations, if you have those nice agrigate driveways ppl get abit anoyed with the marks. also if the popo hear it they can be abit harsh.
https://www.sau.com.au/forums/topic/324356-2-way-diff/#findComment-5287889
My diff guy is Rob at Australian Differential & Transmission Services on Collingwood St Osborne Park, I think his number is 0419 422 246.
Thanks bubba.
Niran
The cusco RS is more friendly than the track oriented MZ.
I had the same issue when choosing my diff so I bought an ATS 2-way carbon diff. Just have to get it fitted now.
Edited by tomcio
https://www.sau.com.au/forums/topic/324356-2-way-diff/#findComment-5289308
    • Haha I do that.. thats when it chirps..The bit point for me is almost non-existent. Otherwise I stall it. But yes, in terms of performance, the clutch is solid af.
    • Greg speaks wisdom. These dirty old Datsuns are only value when they are cheap. When they are not cheap, there is no value. Sounds contradictory, but it's true. We are now 20 years past the hey day of modifying cheap 90s JDM cars for small amounts of money. This is a different world. If you are rich and can afford not to care about what is effectively wasting money on an old Datto shitter, then I have no reason to argue against it. But if you are wanting to experience what we all experienced back in 2005 (and I bought my car last century!) then there is no way to do it.
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
    • Reading all this... hurts lol. I have an ENR34 5MT and I paid an inflated USA price for the car alone, had to do tons of preventative maintenance past that, and so I'm over $30K USD into the car already and haven't even touched power.  I wanted to +t it. Not even trying to make GTR numbers, I'd be happy with 250hp.  Can I get away with paying much less to make that happen?
    • Damn you’ve done well, definitely snapping necks.
