Hi rob and welcome to SAU. A few little details. Please ALWAYS use the search function (top right corner of the page) and see if your topic has been covered before. In almost all cases it has. Please DO NOT just make up new topics willy, nilly - we have enough trouble with important information topics being kicked off the front page in no time for the forums to be filled with redundant threads that have been answered before.
So, I suggest you go do a search and check the stickied 'workshop information' thread in the sticked thread section at the top of the SA forum.
i had my alarm installed by GT Autosound......they did an awesome work.....also had dealings with Auto Perfection and loved the service and quality of work from there too mate.....how far down south are you talking and if your willing to drive up a bit north as well :D
or save money....get a viper alarm and you wont regret it.....loads of functions and pretty cheap as well......then get it installed :P
Also one of the easiest alarms to get past if you know what youre doing :D
But in saying that, no alarm is good enough to stop someone from taking your car that knows what theyre doing anyways...
Edited by SkyHi_33
if someone is going to take my car then they are going to do whatever it takes to get it......regardless of what i do mate.....but a viper is a good enough investment for me
Also probably a good idea to not let people know what alarm you have ;P
I know its unlikely that any SAU member will be considering stealing a car but even car crims in lizbef have net access nowadays
-D
Troy you don't even need an alarm to be covered by insurance unless they absolutely made it clear that they wouldn't insure you without one.......if that was the case, they would tell you exactly what to install.
Having said that, best to always air on the side of caution and check with your insurance company as Troy stated....it's only a phone call.
I have no problem whatsoever with a dirty big blue VIPER symbol flashing on my dash window .... and it would seem the crooks do respect it, as I haven't had anyone touch my car (except for one small testing incident) and I park it everywhere. They also don't know it is the black wired version, I have 2 kill switches, and I have 4 of the loudest piezo screamers you have ever heard .... if their ears can take 30-90 seconds of those things going off in their ears while they hotwire the car, then they can have it.
well I've had Just Cars and Shannons and they both require alarms with proper immobilization points for agree coverage on my car
in case you want a real scare on car theft go here
CARSAFE theft stats per car
good old Adelaide, at least they can come first at something..lol
they must meet these regulations
AS/NZS 4601:1999 certified system include:
➜ Automatic immobilisation within 40 seconds
of ignition switch off;
➜ 2 independent points of immobilisation;
➜ Connections enclosed in security housing;
➜ All black security wiring;
➜ Flashing dashboard LED to indicate that the system
is armed; and
➜ Secure owner PIN override.
the alarm is only as good as the install, and the 100% use of it, even when it's in your garage
and there isn't any alarms that can't be cracked by a pro. if they want your car it's gone.
but it will prevent 95% of the other idiots from taking your car
multi layer security is best and common sense, don't leave your car in the hood..lol
Lol:
YOUR POSTCODE
With 5 or more thefts reported each week, postcode 5108 is one of the highest theft risk locations. We recommend that you read these simple precautions you can take to protect your vehicle from theft.
YOUR CAR
The NISSAN SKYLINE 1998 was not fitted with an immobiliser when it was manufactured and unless it has been fitted with an Australian Standards approved immobiliser since then it is at risk of theft.
New passenger cars sold in Australia are required to have an immobiliser but before 2001 many cars weren't fitted with them. As a result these cars are targets for opportunists to 'hotwire' using something as simple as a screwdriver.
Engine immobilisers provide the most effective barrier available between a thief and your car, as long as you keep your keys safe. Click here for more information.
I am with Just Cars Troy and all they wanted was any alarm with 2 point immobilisation. The original version of my alarm didn't come with black wiring and they didn't give a toss about it when I told them. I even gave them my alarm model number and they looked it up and said it was fine.
so what does an insurance company do when it comes to a pay out if the car is never recovered or burnt to the ground (unable to confirm proper alarm installation if any)........they payout regardless of policy
Well respected insurance companies - such as Shannons - specify a particular standard of alarm system (as per AS/NZS certification) and required documentation to prove installation by an accredited installer - I have both documents noted on my Shannons policy. As for insurance companies such as JC... if one doesn't have anything nice to say, best not to say anything at all.
When I crashed my S15 (my fault) JC were awesome in letting me choose repairer, varying the amount of work done (I added a fg bodykit in leiu of the standard bars they had allowed for). I really can't complain at all.
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
    • OK, now we are ready to get started. You need to remove the air boxes on each side for clearance. The cover is straightforward, undo the clips on the top and lift the front cover out of the rest of the housing. If it is tight you can remove the air filters first. The rear section of the airbox is trickier. On each side you need to remove the Air flow meter wiring which is held to the airbox with a clip; you need to get behind the clip on 2 sides if you want to remove it without breaking it - unclip the harder side and pull on the clip with medium force, then unclip the easier side and it should pop out The airbox is held onto the intake hose with a spring clamp; you need to get a flat bladed screwdriver behind the spring on both sides and pop them outwards. When you have got them in the right unclipped place they will stay there and the airbox slips out pretty freely. Put a rag in the intake to prevent anything getting dropped in there, and also to prevent you seeing that the turbo seal is leaking oil (as they do). Then. The top of the radiator is held by a steel plate, it is secured by 2x10mm and 2x12mm headed bolts . Remove them and remove the plate Also grab the bushings that hold the radiator to the plate on each side so they are not lost!
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
