  • Replies 72
Posted Images
040 has the mesh. its an internal only. whereas 044 is higher rated and can be used either internal or externally (tho in the casse of a 32 internally is a bitch)
if your trackin the car hard which it sounds like you are then get a surge tank. use the current intank pump to feed a surge tank and run an 044 externally.
so when i connect my pump up, do i need relays or anything? obviously the pump needs power and an earth..
i run power from the batter to a 12volt (?) amp, from the amp to the pump, then a earth from the pump to the chassis?
Need a relay, I run mine straight from the battery into the relay ( I used 2 relays for 2 pumps) than use the original wiring from the factory pump to trigger the relays.
otherwise the pump will be on all the time.
  • 1 month later...
ok so today i decided to rip my old rb25 bottom end apart (the one which had massive blowby and pissing oil out the rocker covers at the track)
only to find that the rings are perfect across all 6 pistons, cranks looks good...
any ideas why? was my old engine not stuffed?
See you still pulled 100psi on cyl 5, so it won't be as easy as spotting half a ring missing.
Yes they probably look fine, but pull the rings from no 5 piston and check them in bore 5, chances are it will be out of spec. I didn't read the entire thread but did you do a leak down as well when it was still together?
Also consider a Bosch 023 instead of an 040 if your going intank. The 023 is pretty much an intank version of the 044.
also herd that under boost the afm can break?
do they do map sensors for nistunes? that may be better!?
pull cut the afm housing in half so it can half clamp around the cooler pipe and drill a 20-22mm hole. Use sikaflex to glue it in place. Wont crack under boost and cant be recurved to suit via software.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
