generally the thermostat will open about 85 degrees. if you are running aircon you will want it on most of the time when the aircon is on. if not running aircon then you could still have it come on around 70 degrees. that said, in the missus SSS pulsar, with the aircon off it doesn't turn on until 100 degrees if doing below 20kms, and over 20kmh it turns on at 95 degrees (taken from the workshop manual).
https://www.sau.com.au/forums/topic/325579-thermo-fan/#findComment-5303454
Thermo fans do not need to turn on until quite high temps, certainly more than 10 degrees above the thermostatted temperature.
The fans are employed because the bulk of the cooling is covered by the fact that the car is moving and air is going through the radiator, thus cooling the engine. So why does the engine need to drive a fan if the air movement is doing the job? Having the thermo fan operating all the time or when the thermostat is open is a waste of resources, and simply shifts the load on the engine from driving a fan to driving the alternator.
https://www.sau.com.au/forums/topic/325579-thermo-fan/#findComment-5304156
surely the fan needs to come on below thermo stat temperature . how the f**k is putting water the same temperature back into the engine going to cool the engine?
put a tridon tfs141 thermo switch in the bottom radiator tank . problem solved
youll probably find itll bolt into the factory hole .....
https://www.sau.com.au/forums/topic/325579-thermo-fan/#findComment-5304188
Well we all have different thinking,
I used Tridon TFS 153 in middle of mine,
i have 1980 VC wagon set up with thermo`s MONDAO twin`s water pump high flow bypass kit & fail safe just incase Switch fail`s & fan`s will come on if that dose happen ,as it did when i first had them set up,& has been sweet as since then,
Now i will look at Same set up on MY STAGEA in time,with Factory FAN`S from Nissan Maxima,
Many say THERMO`S are usless & some think there ok ,
But Think about if your SWITCH FAIL`S WHAT WILL COOL WATER THEN,
Cheer`s Chuckie.
https://www.sau.com.au/forums/topic/325579-thermo-fan/#findComment-5304214
:whistling:
if the thermastat is closed no water is flowing through the engine...isnt that what a thermstat does?..stops water flow until engne is at operating temperature...So once the water is flowing is about when the fan should come on...cause until then it is still water so having the fan on is useless..
Edited by Arthur T3
https://www.sau.com.au/forums/topic/325579-thermo-fan/#findComment-5304566
That's just my point. The water is not "the same temperature", it is cooler because it has passed through the radiator and has exchanged heat with the cold air that is passing through the radiator by virtue of the fact that the car is moving.
Having the fan thermostat set higher - as high as 100 - is only a problem when the car is stationary, like in peak hour stop-start traffic. But that is generally only for short periods of time - as soon as the car gets up some speed again, the water will cool down to near the thermostatted temperature, even if the thermo fan has not cut in.
If you don't believe me, why not try it.
https://www.sau.com.au/forums/topic/325579-thermo-fan/#findComment-5305452
:P
what? i may have read you wrong but when the thermostat is closed water still flows around the engine, just not into the radiator (hence when having no thrmostat is bad for your car)
as to the op
you still get heat transfer with water going through the radiator, but airflow through the core increases the amount of energy from the water goes into the surrounding air
and yes, you want the fans to come on AFTER the thermostat opens otherwise the temp will stay below the thermostat temp and it'll take ages to come up to temp = chewing more fuel and running on cold maps longer
colder engines make less power and use more fuel, you want a coolant temp of around 85 consistantly (in traffic or giving it a lash)
https://www.sau.com.au/forums/topic/325579-thermo-fan/#findComment-5314026
its doesnt matter what the f**k your thermo stat is doing .
the job of the fan is to move air through the radiator when there is not enough air moving through it .
if the water in the bottom of the radiator is approaching engine operating temperature the the radiator is not doing its job properly , oh what to do ? turn on the f**kin fan .
and yes put a overide switch in it . or even better hook it to the factory fan wire that comes on when the ac is on or the engine is too hot
the ultimate is 2 speed fans . one speed wired to thermo switch in bottom of radiator other speed wired to factory fan switch so comes on with ac and engine over heat . so either causes half fan and worse case scenario is full noise
and put an overide switch
https://www.sau.com.au/forums/topic/325579-thermo-fan/#findComment-5314457
and obvoiusly no fan is going to be on before the engine is up to temperature . making that piont null and void
But you said in post#5 that
So what is it - on or off below thermostat temp?
Clearly you have no understanding whatsoever about the principle behind the thermo fan and its use in automotive applications.
Humour me and run your car for 1 day with the power to your thermo fan disconnected - let us know if you have major dramas with overheating.
https://www.sau.com.au/forums/topic/325579-thermo-fan/#findComment-5314790
But you said in post#5 that So what is it - on or off below thermostat temp?
the fan needs to come on before the water temperature in the RADIATOR is near the temperature that the thermo stat is set at
the engine and the radiator are two seperate systems the engine only over heats when the radiator is not doing its job.
clearly you do not under stand
the fans job is to move air through the radiator when there is not enough air flowing through it naturally
or does it have another job in your all knowing world??
how do you know if the radiator is not getting anough air ? it heat soaks and the bottom tank approaches the same temerature as the top tank ( which is full of water that just passed through an 82 degree thermostat)
humour me and disconnect your key board while your brain is trying to work
https://www.sau.com.au/forums/topic/325579-thermo-fan/#findComment-5314819
all this time i have been talking about the temperature in the bottom tank of the radiator
which is important in fan function
you have been talking about engine temperature . which is really a delayed (and possible expensive ) way to tell you the radiator is not getting enough airflow and not cooling the water enough so your engine over heats
agree to disagree?
https://www.sau.com.au/forums/topic/325579-thermo-fan/#findComment-5314822
Don't beleive me then, maybe you will believe the manufacturer.
From the Davies Craig instruction sheet - Setting the Thermal Switch:
Turn thermal switch adjustment fully clockwise. The fan(s) should turn off.
Run engine until the engine temperature is about halfway between "normal highway operating temperature" and "too hot". This will indicate a coolant temperature between 5 and 10C higher than normal.
Immediately, turn adjustment very slowly anti-clockwise, just until fan(s) switches on and no more.
Allow the fan to run long enough to reduce the temperature by about the thickness of the temperature gauge needle before it turns itself off.
On a cool day, it should run between 30 and 60 seconds. On a hot day it may be somewhat longer.
If the fans run for more than a few minutes at a time, turn the adjustnment clockwise slightly to increase the cut-in temperature. The fans must be set to cut in above normal operating temperature, otherwise they will run more frequently and for longer periods than necessary, and you may not achieve all the benefits of electric cooling.
https://www.sau.com.au/forums/topic/325579-thermo-fan/#findComment-5314925
You read right but I did word that wrongly...i meant through the radiator ,there is no point having a fan going when the water isnt flowing
Blind elk is all over this one.. When thermostat opens the water in radiator will be cooler than that in the engine so will actually cool the engine for a short time, as it warms up and starts to get over op temp then the fan should come on to cool it Once its back to temp it should stop agian and so on and so on ...
https://www.sau.com.au/forums/topic/325579-thermo-fan/#findComment-5314957
Lachlan vs the world raises a valid point. The coolant temp is generally read at the thermostat, so if the temp probe for the switch is near the thermostat, then you need to set the temp slightly higher than the thermostat opening temp.
If you've set the temp probe in the bottom tank, then this is supposedly cooler than the top tank, so you will need to set the switch lower.
If the radiator outlet water temp is the same as the inlet temp, then correct, there is no heat being removed from the water.
100 deg C water will still cool engine components (some of which are approaching several hundred degrees C) but obviously we start having issues with the water boiling, not being pumped around, effective cooling etc. However, setting the fan to cut in when the radiator outlet temp is higher than the thermostat temp may in fact cause problems as Lachlan has said (because it is coming back into the engine much hotter again). I don't know what the limits are, as I haven't been dumb enough to try this.
https://www.sau.com.au/forums/topic/325579-thermo-fan/#findComment-5315045
but as it says in the quote he posted, it says nothing about the fan turning off due to the coolant being tool cold, just that you won't be getting the full effect of electric cooling (less drain on the engine) and puts extra stress on the fans.
this is where i refer back to the stock settings on the fans on a car that came out with thermos from factory. on the pulsar nissan has it that the fans come on when the aircon is on regardless of engine temp. this means that even if the car is stone cold the fans come on. pretty much any car with factory fitted thermos will be the same. this means that it can't be that bad to have the themo on before the car is at operating temp, and i've never found to it affect how long the car comes up to temp. the car still comes up to temp faster on a hot day with the aircon on from the moment i start the car than it does on a cold day with the aircon off. but as i said earlier, if the aircon is off the fans don't kick in until much higher.
here's a pic of the setup from the workshop manual
https://www.sau.com.au/forums/topic/325579-thermo-fan/#findComment-5316224
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
    • Wife and I are still looking for a new home. One condition was a large enough garage for a full-size lift in one bay. Now if only we could find something... We've been looking for almost a year now.
    • Thanks everyone for the ideas! Sadly, ramps are a no go for me. With young kids at home, I do most of my work late at night while they're sleeping. Starting the car multiple times wouldn't be a great idea.  I'll go see one of those new long reach low profile jacks and take a couple measurements to see if they will fit.
