im looking to do some turbo mods fairly soon....
so far ive looked at a kkr430 (heard mixed stuff bout them...
ive heard they will hit full boost at around 3k on a 25... (seems a little low to me?)
a garret 3076r... is this going to be too big for street... do i really need somthing this big... also not tooo cheap..
or a highflow of my stocker to save rooting round...
feedback from ppl whould be great :P
https://www.sau.com.au/forums/topic/325660-feedback-on-your-turbo-upgrades/
Do you want response or do you want the max power your stock internals can handle
Answer that question and that will help determine which turbo you pick.
I went the gt3076r .82 IW. Will push the internals to the max, but you do loose some response
Allow relistically $3k for ALL the parts required to fit one of these.
I went kkr type on the 30 because I wanted cheap and responsive.
the turbo I have is pretty small for a 30, makes 250kw@16 psi at about 6000rpm and chokes after that.
like Darrin said it really depends what you want.if you are after the most efficient cutting edge stuff, go the garrett ball bearing option
Ok, I'm unsure where to aim
supporting mods are
- greddy profec b spec 2
-3" turbo back
-fmic
-z32 afm
-seimens 620cc injectors
-apexi pod
-shift kit
... After turbos in I'll put z32 and inj in to be nisstuned
I'm thinking it's either hiflow or kkr, what would I expect to pull with either turbo at 14 15 psi?
I'm after response I rekn... How often to you spend at 5500+ rpm on street lol
what would pros and cons be for both?
Both going to be under a grand to get on,
kkr doesn't gave the best record am I not mistaken?
The big thing I found after my turbo upgrade was the need for a higher stall converter. The auto box really excentuates the increased lag over the stocker. I know track times don't really matter to some, but I was quite stunned when I went from a 1.8 60ft to a 2.3.
this will only effect 0-100 time not overall kw tho yeah?
Sorry about that chef, I saw the 260RS in your profile.
The upgrade path is pretty straightforward I reckon a hi-flow is probably the most logical step as there is the least time messing around.
GCG hi-flow, Hypergear Hi-flow, HKS GT-RS, HKS 2835ProS, GT3071, GT3076 are all options each with its own pro or con either based on price or result. Some will need additional parts like dump changes, spacers etc.
I may have a HKS GT-RS kit 2nd hand for sale or a HKS 2835 ProS kit (with a brand new cartridge installed) once I decide which one to keep.
To an extent, yes.
Some people, in the LS1 community, have reported small drops of a few KW's on their dyno figure when upgrading to a higher stall. But really, a dyno is a tuning tool and a difference of a few KW's may just be the price you pay for abit more driveability.
I have a kkr430, it's winding up about the time the stock one does but hits full noise maybe 3500?
I find it a bit laggy, though that may just be attributed to my way-too-large throttle body, but on a smooth acceleration it melds you into the chair quite nicely.
As for power, I've wrangled 270bhp with all the supporting mods and an exorbitantly priced ecu.
Adam, a HKS 2530 would be just what you're looking for IMO.
Very responsive and about 180 awkw @ 10psi with more boost to wind into it, with your kind of mods. I've got 204awkw coming out of mine with 11psi (manual trans) ... about to wind it up to 16psi when I get it on the dyno soon with an aim for (hopefully) the 240awkw mark.
Just in time for the Time Attack next month :)
You still haven't stated your target power but since you have the Z32 afm and the massive injectors you may as well go for 260 -270awkw.
In my opinion the KKR and 2530 won't hack it.
On a budget Hypergear will build you a turbo to do the job or the GCG highflow will make it or if you can get Wolverines 2835 pro S that will do it. If I were in your position again I would buy a GT3076 lowmounted ...that would do the job with capacity to spare.
p.s if you blow the auto people converting to manual generally end up giving their auto boxes away unless they have been modified
pps get a GTR manual box later!
I wouldnt do the kkr .. . .. perhaps on a r32 hacker but not the S2 stagea.
a secondhand 1grand hks-2530 / new $1300 garret gt2860 or gt2871 equivalent would be fine for 230awkw with great response.
fueling would be fine with the injectors/z32/nistune.
**** just noticed - no aftermarket fuel pump listed - what have you got in there atm?
to max out that fueling the GT3076 would be perfect as per above comments from kiwirs4t
perhaps come for a drive with me to see how the 3076 feels. it isnt that laggy tbh, but enough so to notice. she's a heavy car tho
perhaps with a stall converter as mentioned it wouldnt be noticeable?
as it is I really enjoy the gt3076 "highflow" with a flowed head & poncams - Id say with a dirty-30 bottom end it'd be the bees knees
Im nowhere near maxing out the turbo from Bill at ATS, another 10-15% in it left, due to the Toshi remap ecu / Aem Fic-8 holding it back as well as sticking to 450cc S15 injectors.
I'll have to wait for the rb25 nistune option (if it ever comes out, or grab a Vipec ECU) and some 660cc injectors to make the most of the turbo Ive got.
Plus some gearbox work, however as-is the box is fantastic! service & shift kit from MV autos for now.
So, anyways, for you.......
Nistune, fit injectors and z32 afm, fit HKS-2530 or Garret GT2860 for excellent zippy response, bit restricted uptop of powerband, 230-240awkw is possible
fit HKS 2835 or Garret GT3071 for perfect mix of response and power, 250-260awkw is possible
fit Garrett GT3076 for more topend, 270awkw is possible on unopened Neo motor.
Once you get to the 250kw mark, think about a good thicker multi-layered steel headgasket, and excellent oil & water cooling, and a Bosch fuel pump
alrity...
not sure i could push anymore than say 260 at all 4s out of the stock auto trans anyway would i?
i do have a walbro 255lph fuel pump sorry forgot him!
i think the PU version of hypergears highflow will be the option i take... .82 rear housing (.64 on normal highflow)...
shouldny be too laggey i dont think... im more after mid-range tho i think. lets face it how often to we spend at 5500+ rpm... for the sake of a few top end kw's and boost hitting at 750rmp lower... maybe the .64 option is better?
also being in adelaide we have ALOT more cop dramas than the rest of the states.... keeping it "nissan :whistling:" would be a wise path i think.... plus it will still get a decent $ when i decide to move on.
Edited by chef_stagea
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
