run in tune is: 300rwhp at 4500rpm-ish AN
only got a half tune coz it was overboosting. apparanttly torque/boost came on hard and was smokin the tyres on the dyno.
re tune after 1000ks, turn the boost up and rev to 6500-7200rpm see what she makes then.
in reality i really need a new yet another manifold + check what spring is in the wastegate
have vids duno how to put them up as they are mp4.
thing sounds like no other skyline i've heard
somethin like this
  • 3 weeks later...
  • 3 months later...
couldnt say, im assuming standard 32 gtst diff
in saying that, before the rb25det the car was originally an rb20de so wether it has a de diff or det or wether the de diff is even lsd i dont know. but its def an lsd
Edited by Char
Verrrrrrrrrrrrry interested in a vid of said sounds!!!!
Variety of vids would be sweet.
Hybrids are my fascination!
Edited by 045HOW
  • 1 month later...
Similar to my 30/25 with .63 3540 - just had Link installed and fired up for the first time 300hp (225awkw @ 8 -9 psi) - a few things to tidy up and then proper tune at 18psi in about 3 weeks or so.
for anyone interested this is the current tune, or HALF tune really
4th gear BP98 RON
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
