I'm selling my standard R33 GTS-T Series II turbo as I have since upgraded. The standard turbo was NEVER boosted above standard boost pressure, and is in good condition, I never had a single problem with it, and there is no shaft play.
Pics to come shortly, any more details feel free to ask! :down:
Make me an offer!
https://www.sau.com.au/forums/topic/326204-eoi-r33-gts-t-standard-turbo/
$300?
Pics to come shortly, any more details feel free to ask! :/
Make me an offer!
This would go on my rb20 right? if so would you post to s.a. and ill pay the extra money?
If by 'go on' my sr, you mean work, yes, but there's no way it would be a bolt on job.
and lol, do you have an RB20, or an SR20?
p.s. turbo of this size would be a decent enough upgrade on a 2.0L!
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
