Hi folks, I have a fairly mild R33. Mods are limited to a full 3inch catback exhaust, std airbox with custom ram air scoop and BMC filter as well as an R34 intercooler.
I plan to doing the free boost mod in the short term to get 7-8psi the whole time. (maybe 9-10 given my supporting mods?)
Will the std fuel pump flow enough for this setup or will it need to be upgraded? If so what is the reommended part numbers?
My current fuel pump appears in good nick, not noisy, and the car does not appear to be running out of fiel up top, pulls strong and no missing or running issues.
Thanks
Jason
it will be fine to around 230rwkw from memory.... you could/should replace it if you want piece of mind as fuel is very very important and it will be 15 years old by now
If it ain't broke don't fix it doesn't apply to old fuel pumps. If it leans out or fails at high revs bang goes your motor. There is a Walbro with the skyline fitting kit:
http://www.nzperformance.co.nz/store/walbr...mp/prod_80.html
or the Bosch 040 in tank.
i had a strange miss at idle one day so it put a new Walbro fuel pump in and has been great fixed up the miss at idle i was pretty sure it was on its way out :)
there are a lot of fake walbros though so be careful but for $180 bucks its cheap upgreade knowing your not going to run out of fuel
Had it 4 years like this
Any part on a car can fail at any time be it new or old
Edited by jjskyline79
The problem with fuel pumps is if they go from working to failure instantly while driving around normally it's usually fine as the car will usually just stall on you or simply won't start as others have said. It's when they slowly begin to fail and it gradually leans out more and more due to a loss in fuel pressure or when you start giving the car a bit of a thrashing, that's when it can take an engine with it.
PM-R33 is spot on. if it fails this is OK as the engine stalls
its only when you are pushing power out of it, and it cant keep enough
the engine has enough fuel to run, but not enough to be safe, so it leans out
your engine goes bang
we've seen a GTR R34 do this with a pump that couldn't keep up, costly rebuild and dangerous fire
i have basically the same mods as you and my pump is fine.
even though it is still working ok i am going to change it very soon.
i figure for $150-$180 it is a very cheap assurance.
and going by the recommendation of well known skyline mechanic, the walbro is fine to use.
there is one guy in this country who has gone through 4 engines in the last 3 months. he kept rebuilding the engine and was not interested in searching for the reason it is happening.
He is now asking for my help. Pump will be replaced and AFR's will be checked now ;)
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
