Hi folks, I have a fairly mild R33. Mods are limited to a full 3inch catback exhaust, std airbox with custom ram air scoop and BMC filter as well as an R34 intercooler.
I plan to doing the free boost mod in the short term to get 7-8psi the whole time. (maybe 9-10 given my supporting mods?)
Will the std fuel pump flow enough for this setup or will it need to be upgraded? If so what is the reommended part numbers?
My current fuel pump appears in good nick, not noisy, and the car does not appear to be running out of fiel up top, pulls strong and no missing or running issues.
Thanks
Jason
it will be fine to around 230rwkw from memory.... you could/should replace it if you want piece of mind as fuel is very very important and it will be 15 years old by now
If it ain't broke don't fix it doesn't apply to old fuel pumps. If it leans out or fails at high revs bang goes your motor. There is a Walbro with the skyline fitting kit:
http://www.nzperformance.co.nz/store/walbr...mp/prod_80.html
or the Bosch 040 in tank.
i had a strange miss at idle one day so it put a new Walbro fuel pump in and has been great fixed up the miss at idle i was pretty sure it was on its way out :)
there are a lot of fake walbros though so be careful but for $180 bucks its cheap upgreade knowing your not going to run out of fuel
Had it 4 years like this
Any part on a car can fail at any time be it new or old
Edited by jjskyline79
The problem with fuel pumps is if they go from working to failure instantly while driving around normally it's usually fine as the car will usually just stall on you or simply won't start as others have said. It's when they slowly begin to fail and it gradually leans out more and more due to a loss in fuel pressure or when you start giving the car a bit of a thrashing, that's when it can take an engine with it.
PM-R33 is spot on. if it fails this is OK as the engine stalls
its only when you are pushing power out of it, and it cant keep enough
the engine has enough fuel to run, but not enough to be safe, so it leans out
your engine goes bang
we've seen a GTR R34 do this with a pump that couldn't keep up, costly rebuild and dangerous fire
i have basically the same mods as you and my pump is fine.
even though it is still working ok i am going to change it very soon.
i figure for $150-$180 it is a very cheap assurance.
and going by the recommendation of well known skyline mechanic, the walbro is fine to use.
there is one guy in this country who has gone through 4 engines in the last 3 months. he kept rebuilding the engine and was not interested in searching for the reason it is happening.
He is now asking for my help. Pump will be replaced and AFR's will be checked now ;)
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
