I'm sick of looking at the stock boost guage not giving me any clear picture of what I'm boosting to when it goes over 1 bar so I'm gonna replace all 3 guages.
I'm thinking of putting in
Boost guage
Oil temp
Fuel pressure
Any other opinions on the best 3 guages to go in?
Remembering it already has an oil pressure guage in the dash...
https://www.sau.com.au/forums/topic/326763-what-guages-should-i-install/
Boost guage
Oil temp
Fuel pressure
Is there such a thing as a electric fuel preasure guage? I thought you had to run them externally on the bonnet as the preasure lines run straight to them?
personally if you are doing any track driving etc I'd get oil pressure too. the stock gauge is very slow moving and has only a small warning light. a proper gauge has adjustable low pressure warning and will have a buzzer and a light which can save your engine if you suffer oil surge or pump failure.
fuel pressure is a good one and boost is obvious.
water temp and oil temp are both important. i would probably go oil temp before water temp but it's much of a muchness.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
